Activity Forums Adobe After Effects Can`t resize, rotate, etc, imported stuff
  • Can`t resize, rotate, etc, imported stuff
    Posted by Nathan Quattrini on March 8, 2007 at 4:19 pm
    I am having a big problem with AE 7. If i drop one composition into another, I don`t get the values to move it around, resize it etc under the drop down menu. I figured must be something they changed in 7. So I started a new file and imported a jpg, dropped it in a new composition, freshly opened, and bam…same issue…. whats the deal? I can open old projects and the values are where they should be in blue so i can freely drag them and change the values. Now i can only right click and enter an exact value which is useless.
    Click for screenshot
    Nathan Quattrini replied 19 years, 6 months ago 2 Members · 2 Replies
  • Curious Turtle
    March 8, 2007 at 4:34 pm
    Make sure you have the Modes column turned on (it’s the second icon in the bottom left of the timeline window). That’ll sort it.
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Nathan Quattrini
    March 8, 2007 at 4:40 pm
    whew! thank god it was something that easy…it used to default being turned on….grrr…i was ready to cry thinking I corrupted AE yesterday with uninstallong some other software. Thanks
  • leen adly
    November 29, 2020 at 1:24 am
    Hi! I have the same problem, I’ve tried turning on the modes column but it still doesn’t work. is there any other way I can fix the problem?
