Activity › Forums › VEGAS Pro › Can’t render anymore
  • Can’t render anymore
    Posted by Ine Tylczyn on February 4, 2011 at 1:18 am
    Hi, I’m no newbie to vegas but I have a huge problem now.
    Can’t render videos anymore! I always rendered them the same way + network center but today when I rendered video and I then I wanted to render a second one (when I was done with the first) I couldn’t do it. Got a strange message “Failed” and that’s it. In the SV render service my video status says rendering but nothing happens. Not even after few hours. Duration and completed stays 0:00 and 0%
    The image: https://s111.photobucket.com/albums/n151/Kagome_171/?action=view&current=Naamloos-2.jpg
    I tried different things like restoring windows, reinstalling (few times, different versions) deleting the registry…
    Also tried to render another project – couldn’t do that either (the same thing happens)
    I can’t render it the normal way cause after few seconds it says “low on memory” <- tried to fix that – in vain.
    Please help me!
    Stephen Mann replied 15 years, 8 months ago 2 Members · 1 Reply
  • Stephen Mann
    February 4, 2011 at 4:32 am
    Are you using any plug-ins?
    Low Memory or Out of Memory does not mean “Not enough RAM”, though adding RAM can sometimes fix a “Low Memory” waning. A “Low Memory” warning usually means that you have exceeded your commit limit. You need either a bigger page file, more physical memory, or both.
    One of the biggest sources of confusion over memory usage is the whole concept of virtual memory compared to physical memory. Windows organizes memory, physical and virtual, into pages. Each page is a fixed size (typically 4 KB). To make things more confusing, there’s also a page file (sometimes referred to as a paging file and dynamic RAM). Many Windows users still think of this as a swap file, a bit of disk storage that is only called into play when you absolutely run out of physical RAM. In versions of Windows starting with Vista, that is no longer the case. The most important thing to realize is that physical memory and the page file added together equal the commit limit, which is the total amount of virtual memory that all processes can reserve and commit.
    All Windows since XP (and Unix/Linux for that matter) always wants to have page space. Always. Programs like to and are allowed to pre-allocate as much memory as they want. Even if they are never ever going to actually use it. Sometimes those programs properly deallocate memory, sometimes they don’t. Sometimes, programs leave parts of themselves in allocated memory just in case you are going to run that program again. If you have no page file and a program wants to commit some for itself, your PC will crash.
    Paging file configuration is in the System properties, which you can get to by typing “sysdm.cpl” into the Run dialog, clicking on the Advanced tab, clicking on the Performance Options button, clicking on the Advanced tab (this is really advanced), and then clicking on the Change button. I would suggest a value of 1.5X the currently allocated value. Windows supports up to 16 paging files, where each must be on a separate volume, so if you have more than one internal disk drive you could also try enabling a Paging File on your second hard-disk.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
