Activity › Forums › Maxon Cinema 4D › Cant render animation, tried everything.
  • Cant render animation, tried everything.
    Posted by Alexander Eriksson on May 22, 2010 at 9:51 am
    Hi!
    I’m trying to render an animation in Cinema 4D, but it will only render one frame. It works with “Make preview”, but then there wont be any alpha channel so I can remove the background in After Effects. How do I render an animation in Picture Viewer.
    Iv’e tried everything, ive chosen “All frames”, quicktime, millions of colors+, checked alpha channel, “Full render” etc.
    Im so frustraded right now, how can I get this to work?
    Bob Anderson replied 16 years, 3 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    May 22, 2010 at 3:00 pm
    You’re using the render to picture viewer command and not the render view command, right?
  • Alexander Eriksson
    May 22, 2010 at 5:57 pm
    Yeah, I do, but it only renders one frame.
  • Bob Anderson
    June 10, 2010 at 12:33 am
    one thing i typically do to render an animation is pick an encoder along with your movie format. for example advanced render/format/avi movie, then click “options” and under “compressor” tab i get a list of encoders my system has and i pick my “divx” encoder. that’s all it should be. as long as you’ve picked a format,encoder, and the amount of frames to render, and a place to render it, you should not have a problem. hope this helps.
