Activity Forums Apple Final Cut Pro can’t remember – want to bring the song down in volume so that I can hear the voiceover then bring the song back up
  • can’t remember – want to bring the song down in volume so that I can hear the voiceover then bring the song back up
    Posted by Cybil Lake on September 19, 2017 at 3:34 am
    Hello! I have a song in the background of some voiceover. I want to bring the song down in volume so that I can hear the voiceover then bring the song back up the the voiceover is done. I can’t remember how to make a point so that I can do this.
    I believe it used to be that you would hit P for pen and you could make a couple dots and bring the audio down. Now I don’t know how to do it.
    thanks!
    Cybil Lake replied 8 years, 11 months ago 3 Members · 3 Replies
  • Jeff Kirkland
    September 19, 2017 at 5:07 am
    Hold down the alt key as you click on the volume line. Or select a range under the voice over and just reduce the volume inside the range, which will add points and a bit of a fade either end.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Scott Witthaus
    September 19, 2017 at 10:36 am
    Jeff has it right. I use the range tool in this situation all the time, and then you can adjust the audio animation to your taste by moving the keyframes about.
    Scott Witthaus
    Owner, 1708 Inc./Editorial
    Managing Partner, Low Country Creative LLC
    Professor, VCU Brandcenter
  • Cybil Lake
    September 19, 2017 at 9:10 pm
    thank you!
