Activity › Forums › Adobe After Effects Expressions › Can’t reference self position with valueAtTime
  • Can’t reference self position with valueAtTime
    Posted by Tom Ono on May 19, 2020 at 4:22 pm
    I thought position[0] would be 200(time>=2)but wouldn’t.
    Position[0] is 1234.2
    why?
    thanks
    if(time<2){
    x=time*200;
    [x,value[1]];
    }else {
    transform.position.valueAtTime(1);
    Tom Ono replied 6 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 19, 2020 at 5:55 pm
    When an expression references the value of the property hosting the expression, it always get the pre-expression value. Expressions have no memory, so an expression can’t access its own results from previous frames. There are usually ways to work around that limitation though, depending on what you’re trying to do.
    Dan
  • Tom Ono
    May 20, 2020 at 11:45 am
    I was able to work around that limitation by just using the copy layer .
    Thank you so much.
