Activity Forums Adobe After Effects Expressions Can’t Reference Layers of Parent Comp with Expression in CC 2014
  • Can’t Reference Layers of Parent Comp with Expression in CC 2014
    Posted by Kevin Burke on September 26, 2014 at 5:56 pm
    I’m getting an error when I pickwhip to reference a layer in the parent comp of my layer with the expression.
    This does not make any sense to me…if I pickwhip, the layer name should be correct. Does anyone know what might be happening? Thank you.
    Quba Michalski replied 11 years, 11 months ago 3 Members · 2 Replies
  • Kevin Camp
    September 26, 2014 at 7:15 pm
    it should work that way. double check that you have the latest update.
    if so, you might try a reboot and see if that has any effect.
    if that doesn’t help, file a bug report by either choosing help>send feed back, or use this link:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Quba Michalski
    October 6, 2014 at 9:37 pm
    Is it at all possible that you have more than one composition called “grid” ? Just a wild guess, as the error, indeed, does not make sense.
    Quba Michalski
    qubahq.com
