can’t record with audion3 win7-64
I have spent hours on this and have used Audition with an M-Audio firewire box in the past. I am surprised I can’t get this to work. I have installed Audition 3 with the 64bit version of Windows 7. I am connecting the Sennheiser mics (XLR inputs) using an M-Audio Fast Track Pro box. I feel that the box is working correctly. I can talk into the mics and hear through the headphones. I can playback files in Audition, see the waveform, and hear through the headphones. I have the audio hardware set up for M-Audio ASIO and the default input set to 01M – Line in 1 Fast Track Pro. Everything seems to be set right but when I hit the record button, I get nothing. The playhead moves but I see no waveform and nothing is recorded. The machine is an i7 quad at 2.8 ghz. I tried raising the latency setting but it had no effect. The machine is plenty powerful. I would appreciate help from anyone. I’m aboput to go crazy.
