Activity › Forums › Adobe After Effects › Can’t read frame from file
  • Can’t read frame from file
    Posted by Julian Kauffmann on August 12, 2008 at 12:51 pm
    We use proxies in our work flow, pre-rendering certain comps before rendering out the final project. For the most part this works fine, but occasionally we’ll get an error that reads: “Error (4) reading frame from file.” It’s always the same comp but it doesn’t cause the problem in every project.
    We use the quicktime codec with Tiff compression. Could it be a memory issue? Any help would be greatly appreciated. The error always pops up at the most inconvenient time — of course.
    Julian
    Julian Kauffmann replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
