Activity Forums Apple OS X can’t re-install OSX on macbook with original install disk…
  • can’t re-install OSX on macbook with original install disk…
    Posted by Elin Grome on February 11, 2012 at 1:38 pm
    Hi guys,
    Im a long time mac user and ive got a problem ive not experienced before.
    The macbook wont boot – just sticks on the grey apple logo screen – disk utility says disk needs repair…
    So
    1. Backed up data, restarted from boot disk (apple -c ) and erased disk
    2. Disk utility says disk is ok – but…
    3. When I try to install clean system installer stops at “33 minutes remaining” and gives message “cannot be installed on this computer” and a message about some files couldnt be copied….”
    Going on advice from another forum I tried again but using a custom install and unchecking all additional installs.
    No luck – installer stops after ’20 mins remaining’ – same error message.
    I tried booting into macbook from my imac in target mode (T key, firewire) and thought i could use techtool to try and resolve issue; but techtool only seems to allow me to repair my local drives – I doesnt even see the macbook….
    Re. system, snow leopard – I cant remember what release or when i last updated – but I imagine the installed system would be a later release than the disk as its a couple of years old…
    Does anyone have any ideas?
    many thanks,
    Elin
    System.
    2009-2010 Macbook pro 13′
    Snow leopard on supplied disk.
    It’s all the those pesky details :p
    Elin Grome replied 14 years, 6 months ago 1 Member · 1 Reply
  • Elin Grome
    February 14, 2012 at 5:01 pm
    FYI – in the end i upgraded to lion using laptop as target firewire disk. installed fine.
