Activity › Forums › Apple Final Cut Pro Legacy › can’t print to video from timeline
  • can’t print to video from timeline
    Posted by Mickie Shaw on May 23, 2006 at 8:58 pm
    I am on a new G5 with dual processors and 2 gig of ram running my old FCP 3. When I print to tape or try to play any clip from the time line out my DV deck only gets audio and a freeze of the first frame and no TC. I am connected with firewire. Have tried many solutions including deck settings, external video settings, frame settings, turn the deck off and on, restart, just to name a few. About ready to kick the tower.
    Any suggestions. Will be very grateful.
    Mickie
    Mickie Shaw replied 20 years, 4 months ago 2 Members · 2 Replies
  • Shane Ross
    May 23, 2006 at 10:12 pm
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Mickie Shaw
    May 24, 2006 at 1:32 am
    tried your proceedures and didn’t work. :0( Any other ideas?
