Activity › Forums › VEGAS Pro › can’t position logo low or high
  • can’t position logo low or high
    Posted by Jake Reborn on May 17, 2014 at 1:56 am
    Hi Dudes,
    I hope this is an easy one…
    I have a logo. I would like to position it in the bottom left-hand corner of the frame, but when i edit the event, moving logo to the desired position it is masked by an invisable barrier. If i move the logo slightly higher only the bottom half is masked.
    Jake Reborn replied 12 years, 4 months ago 4 Members · 4 Replies
  • Mike Kujbida
    May 17, 2014 at 2:58 am
    Option 1. Use Track Motion to position the logo.
    Option 2. Open Pan/Crop on the logo, right click and select Match Output Aspect, zoom out and position as desired.
  • Graham Bernard
    May 17, 2014 at 4:21 am
    Mike’s solution will work. However, I prefer to make the graphic already positioned within a transparent “plate” and lay this on top of video and use P/C for final tweaking.
    Grazie
  • Steve Rhoden
    May 17, 2014 at 7:37 am
    Both Mike and Graham offered you two excellent
    solutions for this process.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Jake Reborn
    May 18, 2014 at 11:07 am
    Thanks guys.
    Mike’s methods both worked. nice and easy.
    Graham’s method is to use another program pre-vegas.
    I tried to do this in ilustrator but coudn’t.
    Nice One. This is an amazing comunity. J.
