Activity Forums VEGAS Pro Can’t Play or Convert AVI File From Home Movie Camera!
  • Can’t Play or Convert AVI File From Home Movie Camera!
    Posted by Ken Matson on June 7, 2013 at 2:07 pm
    This one has me stumped – must be some kind of encryption or something? I dunno.
    I was given a camera card (SD) from a home movie camera to put onto DVD. Do it all the time. These are AVI files and MediaInfo shows them as mjpg – see bottom if you want the details.
    ANYWAY – in vegas – they import – audio is fine – but video is “Scrambled” with all kinds of crazy colors and stuff. These files play FINE in WMP and Quicktime Player and they actually play fine if put into DVDA directly.
    I try to convert them in AVS Video converter, and depending on which file type I choose, I get either only a split second of video that converts (like a 2 minute video will convert to a 15 frame video) or it converts but has a gray or green semi-transparent bar and some other noise across bottom 1/3 or so of picture. Also crashed AVS a couple times. Any Ideas Anyone?
    Media info Data is below:
    General
    Complete name : E:Transfers 2013.06SUNP0003.AVI
    Format : AVI
    Format/Info : Audio Video Interleave
    File size : 67.1 MiB
    Duration : 1mn 28s
    Overall bit rate : 6 374 Kbps
    Video
    Format : JPEG
    Codec ID : MJPG
    Duration : 1mn 28s
    Source duration : 1mn 28s
    Bit rate : 8 131 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 19.982 fps
    Color space : YUV
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.442
    Stream size : 85.5 MiB
    KenM
    Sound Works R&P
    Erin Sparks replied 13 years, 2 months ago 4 Members · 3 Replies
  • Stephen Mann
    June 7, 2013 at 2:49 pm
    Sounds like a codec problem. WMP, Quicktime Player and VLC use their own Codecs, but Vegas and most other professional editing programs use the codecs installed by Windows. (Codecs used to view videos are freely available from the codec patent owners. Codecs to encode video come with royalty payments.) Sony has licensed or outright own some of the most common codecs that are installed by Vegas.
    Here is a utility that will examine your video file and tell you what codec was used to create the video:
    WARNING – NEVER, ever install a codec pack. These are made for gamers for best player performance and often replace the otherwise good quality codecs installed by Vegas with ones really inferior for encoding video.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Rofrano
    June 8, 2013 at 9:42 pm
    Vegas has built-in support for M-JPEG so it shouldn’t be a codec problem. If they play fine in QuickTime Player then you might want to purchase QuickTime Pro and convert them to another format with QuickTime.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Erin Sparks
    June 15, 2013 at 5:24 am
    I have the same problem. AVIs from other sources work fine but AVIs from my camcorder give an error message if I try to insert them into a project. I use FreeMake to convert them to WMVs.
