Activity Forums Apple Final Cut Pro Legacy Can’t play clips cant render…
  • Can’t play clips cant render…
    Posted by Lawrence Gray on August 14, 2013 at 7:34 am
    I have a problem. My FCP Pro 7.03 has been crashing frequently. Now it won’t render… always out of memory no matter how many times I clear the render manager… and now won’t play or import clips… I get a Fin-00000001 cannot be found warning.
    Also, when I closed down FCP and tried to play the clips in Quick time I get the sound but no vision. If I hit the time line control on the player I can move to a still and see a frozen image but it won’t play the video.
    I’ve got a feature film on this. So this is a little worrying…
    Any cure for this?
    Craig Johnson replied 12 years, 7 months ago 6 Members · 15 Replies
  • 15 Replies
  • Shane Ross
    August 14, 2013 at 7:46 am
    Sounds like you have a Quicktime Reference file in the project, and sequence. Because QT reference files aren’t fully self contained…they reference media files and renders. And if any file or render file is missing, FCP, or QT, will not play the file…and keep asking for the missing media. Almost like an infinite loop.
    You need to delete the QT reference file from the project.
    Shane
    Little Frog Post
  • Alexander Kallas
    August 14, 2013 at 8:14 am
    You could also try trashing the FCP prefs.
    Cheers
    Alexander
  • Lawrence Gray
    August 14, 2013 at 9:16 am
    Well the clip was rendered out to quicktime though I wouldn’t have thought it was a reference file.
    However, I have to trash it as it won’t play in quicktime or FCP. However, I’m trying to create the clip again and apparently I can’t render out anything at the moment as it keeps throwing up Out of Memory errors.
    It was doing that for every render on the timeline and I’ve been deleting renders from the Render Manager to deal with that and think that’s caused the problem with the quicktime render.
    I’m a little concerned about creating even more problems… Essentially this stuff only happens to clips rendered out to quicktime? And I can’t hurt the original clips that are all pro res renditions of DSLR files?
    Any idea what the best way of outputting from the time line is so that I can avoid this issue?
    I upgraded to Mountain Lion and I note a number of people have had this sort of issue.
    Lawrence Gray
  • Lawrence Gray
    August 14, 2013 at 10:04 am
    Just tried to render out through Compressor and it fails to do that as well.
    I can’t seem to render anything at all.
    Lawrence Gray
  • Lawrence Gray
    August 14, 2013 at 10:57 am
    Hmm… I actually can’t find the /library/preferences… I’m sure it was there at one time but it isn’t there now. The upgrade of the OS seems to have made it disappear!
    Any idea of how to find it. It doesn’t appear in spotlight!
    Lawrence Gray
  • Bret Williams
    August 14, 2013 at 12:31 pm
    When you export to QT, make sure you have “make self contained” checked otherwise it creates a reference file- referencing render files in your sequence. Files that will get deleted as you make further changes to a project or delete render files. Then of course if you have brought that reference file into your project, it will throw up errors because it’s missing media.
    Reference files always have their own self contained audio. That’s why you still hear sound in QT.
    Hold down option and click on the go menu in finder and you’ll magically see the “library” folder choice appear. Apple has conveniently hidden that folder for us as of Lion. But I suspect your prefs are fine.
  • Alexander Kallas
    August 14, 2013 at 12:35 pm
    [Lawrence Gray] “Hmm… I actually can’t find the /library/preferences… I’m sure it was there at one time but it isn’t there now. The upgrade of the OS seems to have made it disappear!
    Any idea of how to find it. It doesn’t appear in spotlight!”
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    Cheers
    Alexander
  • Rafael Amador
    August 14, 2013 at 1:49 pm
    Do you have any strange element in your time-line: Big stills, Motion projects?
    Save your project with a new name and try to render again.
    rafael
  • Lawrence Gray
    August 14, 2013 at 4:25 pm
    I’ve just got pro res 422, air, and wav files on the time line.
    I’ve opened it in new projects several times to try clear the problem but afraid I still have it.
    I keep getting a green screen until I click on the time line clips. And if I move things on the time line I’ve been getting more and more crashes. Similarly I’ve been getting crashes from rendering, when it doesn’t stop the rendering by an out of memory error.
    I haven’t trashed the preferences yet… I’ll try that when I can.
    I’m assuming it won’t corrupt any files and make things worse?
    Lawrence Gray
  • Lawrence Gray
    August 14, 2013 at 5:17 pm
    I trashed the preferences. And reopened the file. Tried to render a time line and FCP crashed.
    This is looking horribly serious.
    Lawrence Gray
