Activity Forums Apple Final Cut Pro Legacy Can’t play clips cant render…
  • Lawrence Gray
    August 14, 2013 at 5:44 pm
    Checked the settings. It’s on Make Self Contained. I think I’ve always had it on that. I use this to render out finished projects. So why it required these .fin files I don’t know.
    I’m trying again at the moment but i keep getting the Out of Memory problem. And even managed to crash the entire computer. So I’m wondering if I have a video card problem going on as well.
    Lawrence Gray
  • Rafael Amador
    August 15, 2013 at 2:42 am
    [Lawrence Gray] ” So why it required these .fin files I don’t know”
    What is “.fin files”?
    rafael
  • Lawrence Gray
    August 15, 2013 at 3:53 am
    I get a “Fin-00000001 cannot be found” warning meaning a render file is missing.
    Though why there should be a render file for something that has been created as an independent movie from the Quicktime output option I don’t know!
    Lawrence Gray
  • Lawrence Gray
    August 16, 2013 at 2:03 am
    I’ve found the solution! Project files are over 100mbs. and this causes the problem.
    I’ve been eliminating sequences from the project file and found that I can render again.
    Lawrence Gray
  • Craig Johnson
    February 23, 2014 at 4:57 am
    When you say project file, specifically what files are you referring?
Page 2 of 2
