Activity Forums Adobe Premiere Pro can’t play avi files in the source monitor!
  • can’t play avi files in the source monitor!
    Posted by Kash Kalegi on August 3, 2009 at 1:12 am
    I’m new to premiere, so got lots of dumb questions 🙁
    1. can’t play avi files in the source monitor. I imported an avi files in premiere, but when I open and play it in source monitor, it doesn’t show the file fluently. The sound is fine, but you only see random frames of the video making it impossible to set start/end points for editing.
    Please help
    Alexander Jusay replied 16 years, 11 months ago 2 Members · 5 Replies
  • Alexander Jusay
    August 3, 2009 at 4:26 am
    This could be a lot of things: slow CPU, slow hard drive, mismatched project settings,codec or video card problems, etc. What are your specs?
    Alexander Jusay
    http://www.editkovideomo.com
  • Kash Kalegi
    August 3, 2009 at 11:43 pm
    Thanks for the reply. well I put together this bad boy just couple months ago, so I doubt the problem would be with the speed etc. anyway here are the specs:
    motherboard: M3A78-T
    CPU: AMD Athlon 64 X2 Dual Core Processor 5000+ 2.61 GHz
    memory: 4gb
    hard drive: western digital, 32mb cashe, 7200 RPM
    parachuter2b
  • Alexander Jusay
    August 6, 2009 at 5:48 am
    You have a fast system indeed. I guess it must be a codec problem if the file is AVI. Although, if you are working on HD footage or uncompressed avi, the hard drive must be having a hard time keeping up with the data rate. My quad core 1 TB hd system couldnt keep up until I use RAID.
    Alexander Jusay
  • Kash Kalegi
    August 11, 2009 at 2:41 am
    no it’s not HD, plus the speed is more like 30sec/frame rather than the other way around (no joke!) so I’m more inclined to think that you’re right about the codec issue! which codecs should I get and where would I get them from!?
    parachuter2b
  • Alexander Jusay
    August 11, 2009 at 7:01 am
    You can try this:
    https://www.free-codecs.com/download/Codec_Pack_All_In_1.htm
    then download and install the codecs from microsoft website:
    1. windows media codecs
    2. windows media components for quicktime
    The codecs from microsoft will overwrite whatever rogue codecs you might have previously installed, which is good. Also, try updating your media player and directx. I believe Premiere is using Directshow for playback so fixing these will likely fix your premiere as well.
    Hope this helps you.
    Alexander Jusay
