Activity Forums Avid Media Composer Can’t output 24p on Avid 4.3…
  • Can’t output 24p on Avid 4.3…
    Posted by Dennis Przywara on January 3, 2007 at 10:18 pm
    I’m running avid 4.3, working on a project that was digitized at 23.97. I’ve tried to do an output directly to my Mini Dv cam, but all i get is a blank screen. I’ve also noticed that my “Enabled Digtial out” and “Digital cut” is shaded out. Does anyone know how to solve this problem? Will i need a mojo to output now? If I get a mojo, will that cure the “Enabled Digtial out” and “Digital cut” problem as well?
    Michael Phillips replied 19 years, 8 months ago 2 Members · 1 Reply
  • Michael Phillips
    January 4, 2007 at 5:13 pm
    Direct output over FireWire came in 5.1. All previous versions required a Mojo for output.
    Michael
    anything 24fps
