Activity Forums Apple Final Cut Pro Legacy Can’t open XML file
  • Can’t open XML file
    Posted by Giuliano Perez on April 10, 2010 at 10:03 pm
    I’m working on a project which someone else started editing on macbook pro and FCP7. I have similar computer, BUT FCP6. He’s given me the project on a XML file. When I open the file it takes me through the process of selecting where I want the project to open and how want to call it. Then very quickly import the files, BUT then it gives a warning message saying:
    “No-critical error were found while processing an XML document. Would you like ot see log of errors now?”
    I have said yes and no, however in both instances I’m left with FCP open but no project whatsoever. When I click to open the new project file created it tells me that the project is already open.
    What am I doing wrong?
    Is it that it just won’t work going from FCP 7 to 6?
    Please help.
    A desperate creative (no so much right now) person.
    Giuliano.
    Giuliano Perez replied 16 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    April 10, 2010 at 11:01 pm
    Did they export an XML, version 4? Version 5 won’t work.
    Shane
  • Giuliano Perez
    April 10, 2010 at 11:46 pm
    They exported version 1, 2 ,3 ,4 and 5. Have tried all of them.
    With every instance FC imports the XML document, giving me the warning message I mentioned before, it then asks me If I want to see the error log, whatever the answer, I end up with FC open but no project.
    When I go to open the new create project file, it tells me that the project is already open.
    Was there a mistake when first exporting the XML file? I have the drive with all the project content (clips,etc)
