Activity Forums Apple Final Cut Pro Legacy Can’t open sequence, “File Not Found” Message
  • Can’t open sequence, “File Not Found” Message
    Posted by Kwesi Johnson on December 28, 2007 at 7:03 pm
    I have tried to open up a specific sequence in a FCP file and it will not open. I get a “File not found” messege, followed by an “Out of Memory” message. I then went back to the autosave vaults and they didn’t open that sequence.
    I then made the sequence offline through the Media Manager, re-digitized the media at 10 bit, and that worked for a bit, then I got the same “File Not Found” message followed by “Out of Memory” message.
    Thanks for your time, Kwesi
    David Bogie replied 18 years, 9 months ago 2 Members · 1 Reply
  • David Bogie
    December 31, 2007 at 4:05 pm
    Without being able to see your machine, I’m only guessing, but it sounds like capture media is going to a folder that you do not really have access privileges for. This also happens when reference moves are created form media that goes offline.
    bogiesan
