Activity › Forums › Apple Final Cut Pro Legacy › Can’t open P2 files
Can’t open P2 files
Posted by Bruce Assardo on November 22, 2011 at 8:57 pmI am trying to Log & Transfer some P2 footage and am getting this message and it won’t give me access to the footage…
“FILE” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.
Bruce Assardo replied 14 years, 10 months ago 4 Members · 10 Replies -
Shane Ross
November 22, 2011 at 9:16 pmChoose the ROOT folder that contains the CONTENTS folder. Don’t go digging.
Here…tutorial: Tapeless Workflow for FCP 7 Tutorial
If you did that and STILL get the error…well, is the full card structure there? Contents…inside 6 folders with names like VIDEO, VOICE, CLIP, AUDIO, PROXY…?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Bruce Assardo
November 22, 2011 at 9:19 pmThanks for getting back to me…yes all those folders are there
Neil Patience
November 22, 2011 at 9:20 pmThis error usually but not always happens when people make copies of files but do not retain the original file structure.
Are you working directly from the P2 cards or copies ?
I usually find its best to make copies from the cards onto a media drive, the proviso is make sure you absolutely retain the file structure as the originals and then import from there.
Shane Ross did a P2 workflow ages ago – may be useful
https://library.creativecow.net/articles/ross_shane/p2fcp6.php
https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
best wishes
Neil
http://www.patience.tv -
Bruce Assardo
November 22, 2011 at 9:23 pmWe copied the contents of the cards onto my firewire drive. Is there a missing component i can add now? A Last Clip kind of thing?
Shane Ross
November 22, 2011 at 9:30 pm4 minutes late again Neil…hee!
Do you have the file structure I outline in the tutorial? A folder with a unique name, then CONTENTS and LASTCLIP, and in the CONTENTS the VIDEO, VOICE, PROXY, CLIP, AUDIO…? Missing anything?
Shane
Little Frog Post
Shane Ross
November 22, 2011 at 9:36 pmAnd did you choose the root level folder? Not the CONTENTS folder, or any of the ones inside, but the folder that the contents folder is inside. Just choose THAT folder.
Shane
Little Frog Post
Neil Patience
November 22, 2011 at 9:41 pmI know – thats 3 nil to you – going to have to speed up my typing skills 🙂
best wishes
Neil
Steve Eisen
November 22, 2011 at 10:49 pm[Bruce Assardo] “We copied the contents of the cards onto my firewire drive. Is there a missing component i can add now? A Last Clip kind of thing?”
The Last Clip is needed. Not all is lost. You can recreate the Last Clip. Google for the answer.
This is how it should look:
https://support.apple.com/kb/HT1847Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
