Activity › Forums › Apple Final Cut Pro Legacy › Can’t Open FCP 4.5 Project in version 5!!
Posted by Max Marini on January 20, 2006 at 7:16 amCan’t Open FCP 4.5 Project in version 5!! Keeps telling me “Out of Memory” when I try to access the timeline. Also, can’t open up any of the attached media in fcp5.
Is there a quick fix??Frank Nolan replied 20 years, 8 months ago 4 Members · 6 Replies -
David Bogie
January 20, 2006 at 2:56 pmHere’s what I know: It should work flawlessly. I had absolutely no issues opening any of my 4.0 or 4.5 projects into 5.0.
Try supplying some additional information about the media.
bogiesan
Frank Nolan
January 20, 2006 at 7:29 pm[Max Marini] “Keeps telling me “Out of Memory” when I try to access the timeline.”
If you are at the point of accessing the timeline you would already have a project open, no? Are you sure it wont open the project or is it that it wont open a sequence within your project?
Max Marini
January 22, 2006 at 2:56 amI guess it won’t open the sequence within the project. It gives the message: Error – Out Of Memory.
It also won’t open any of the clips in the project.
This was a project initially created in FCP Express and then upgraded to FCP 4.5. Is it possible you can only upgrade once?? -
Max Marini
January 22, 2006 at 2:57 amMedia was originally worked on in FCP Express2 and the upgraded to FCP 4.5. Is it possible you can only upgrade the project once?
Walter Biscardi
January 22, 2006 at 2:11 pm[Max Marini] “This was a project initially created in FCP Express and then upgraded to FCP 4.5. Is it possible you can only upgrade once??”
What I would do is launch the project in FCP 4.5.
Now create a New Project.
Now move all the bins and sequences from the original project to the new one.
Save the New Project with an appended name, like Project REV 1.
Open a Sequence and ensure that it plays correctly.
Quit FCP 4.5
Now try to open the Revised project in FCP 5.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Frank Nolan
January 23, 2006 at 9:08 am
