Activity Forums Avid Media Composer Can’t open bins in drive dig’d on Adrenaline into Xpress Pro project
  • Can’t open bins in drive dig’d on Adrenaline into Xpress Pro project
    Posted by Cathy G’nator on February 26, 2007 at 5:35 pm
    I’ve just received a drive for my current project which was digitized on an Adrenaline system. The material was dig’d at 15:1, 29.97 NTSC from DVCPro HD at standard def. However, none of the bins will open in Xpress Pro. The message I get is “failure setting file type on bin”. Is there something in my settings that I need to change for this project, or am I running up against the common problem where one can’t open bins from a “higher” version of AVID into a “lower” one?
    Thanks folks!
    Cathy G’nator replied 19 years, 6 months ago 1 Member · 1 Reply
  • Cathy G’nator
    February 26, 2007 at 6:42 pm
    I have solved this problem using Xpress Pro Help–should have gone there to begin with. My mistake was in not moving the bin files from the hard drive to my projects folder….
