Activity Forums Adobe After Effects Can’t open an After Effects 10 file in After Effects CS4
  • Can’t open an After Effects 10 file in After Effects CS4
    Posted by Julie Mullins on January 15, 2011 at 12:19 am
    Hi!
    Today I sent myself an AE project from work (with all the collected files and everything). When I tried opening it at home I got the message:
    “The file you are attempting to open was created with After Effects version 10.0 (unknown) and cannot be opened with this version”
    I thought all the computers at the office were running on CS3, but maybe the one I was working on today (not the one I usually work on) isn’t. Is there any way I can get this project to open so I can work on it from home? Why wouldn’t the current version of AE open a file from a previous version? It’s pretty much all just 3D layers of animated type with a camera.
    Todd Kopriva replied 13 years, 3 months ago 3 Members · 3 Replies
  • Todd Kopriva
    January 15, 2011 at 2:26 am
    But that’s the opposite of what you just asked about.
    After Effects CS5 (which is After Effects 10) can open files created in After Effects CS4 (and several earlier versions).
    After Effects CS4 (which is version 9) can’t open files created in After Effects CS5.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tony Sanchez
    May 21, 2013 at 7:01 am
    Which is stupid… Adobe should allow projects created with a newer version to be worked on with at least the previous one. That some features may not be compatible is one thing, but not being able to even open the project shows Adobe’s will to force users to upgrade to the latest version. It’s going to be really interesting now that Adobe has moved its Suites to the cloud. I think a lot of people are going to be using CS4/CS5/CS6 for a very long time unless the competition takes advantage of this tremendous mistake from Adobe.
  • Todd Kopriva
    May 21, 2013 at 4:02 pm
    This script makes transferring projects between versions relatively convenient:
    https://aescripts.com/pt_opensesame/
    After Effects team blog
