Activity › Forums › VEGAS Pro › Can’t open a specific video file?
  • Can’t open a specific video file?
    Posted by Daniel Mangoianu on July 3, 2017 at 12:26 am
    I’ve been trying for a while to open a video file in Sony Vegas, as it gives me a message saying either it has been corrupted or is an unknown file type.
    Here are the specifications:
    format: mp4
    video encoder: libx264 (h264 i’m guessing)
    pixel format: yuv420p
    – 40 mbps
    audio encoder: ac3
    sample format: fltp
    sample rate: 48k
    bitrate: 320 kbps
    I am able to change these settings when recording, but i’m not sure what video encoder works with which audio encoder, container, etc.
    Can anyone help?
    Graham Bernard replied 9 years, 2 months ago 2 Members · 5 Replies
  • Graham Bernard
    July 3, 2017 at 8:19 am
    [Daniel Mango] “Can anyone help?”
    Get the free download of MediaInfo. Point it at your file. Get the reports and bring ’em back here.
    * Grazie
  • Daniel Mangoianu
    July 3, 2017 at 9:41 pm
    Alright, I did what you asked. Here is the report in ‘text’ format:
    General
    CompleteName : D:\ADD MOTION BLUR.mp4
    Format : MPEG-4
    Format_Profile : Base Media
    CodecID/String : isom (isom/iso2/avc1/mp41)
    FileSize/String : 2.61 GiB
    Duration/String : 9 min 9 s
    OverallBitRate/String : 40.8 Mb/s
    Encoded_Application/String : Lavf56.40.101
    Video
    ID/String : 1
    Format : AVC
    Format/Info : Advanced Video Codec
    Format_Profile : High@L5
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 5 frames
    CodecID : avc1
    CodecID/Info : Advanced Video Coding
    BitRate/String : 40.0 Mb/s
    Width/String : 1 920 pixels
    Height/String : 1 080 pixels
    DisplayAspectRatio/String : 16:9
    FrameRate_Mode/String : Constant
    FrameRate/String : 60.000 FPS
    ColorSpace : YUV
    ChromaSubsampling/String : 4:2:0
    BitDepth/String : 8 bits
    ScanType/String : Progressive
    Bits-(Pixel*Frame) : 0.322
    StreamSize/String : 2.59 GiB (99%)
    Encoded_Library/String : x264 core 148 r2665 a01e339
    Encoded_Library_Settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=40000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    ID/String : 2
    Format : AC-3
    Format/Info : Audio Coding 3
    Format_Settings_Endianness : Big
    CodecID : ac-3
    Duration/String : 9 min 8 s
    BitRate_Mode/String : Constant
    BitRate/String : 320 kb/s
    Channel(s)/String : 2 channels
    ChannelPositions : Front: L R
    SamplingRate/String : 48.0 kHz
    FrameRate/String : 31.250 FPS (1536 SPF)
    BitDepth/String : 16 bits
    Compression_Mode/String : Lossy
    StreamSize/String : 20.9 MiB (1%)
    ServiceKind/String : Complete Main
    Default/String : Yes
    AlternateGroup/String : 1
  • Graham Bernard
    July 4, 2017 at 3:22 am
    Good. This has confirmed the audio is AC3. Vegas has a history of difficulty with importing AC3, there are some exceptions and workflow workarounds to this, but mostly it’s not a good idea to involve AC3 anywhere in the import workflow. You can go ahead and research the options in getting AC3 into VP. My thoughts would be to irradicate any AC3 Capture.
    Also do check the part of the MediaInfo reporting logs that reveal the available CODEC on your PC. This will further indicate if your PC will deal with both the Video and Audio content.
    I hope some of this helps.
    * Grazie
  • Daniel Mangoianu
    July 4, 2017 at 7:08 pm
    Would there be a way to convert the AC3 to lossless format without re-recording the entire thing? Any free programs that would do so?
  • Graham Bernard
    July 5, 2017 at 5:15 am
    [Daniel Mangoianu] “Would there be a way to convert the AC3 to lossless format without re-recording the entire thing?”
    On a tangential approach I’ve imported my own DVDs back into Vegas Pro. These where DVDs I’d created/burnt using DVDA. Now, realise that these would have been videos compressed down to a lower res MPEG. So how lossless you’d want, I dunno!
    Any free programs or any programs I’d point you to? I haven’t used nor needed to – sorry ???? …. My workflows are straightforward and have been honed down by bad hard-knock purchases I’ve made over the decades, resulting in a wish to keep my Capture to Import to Edit to Deliver as seamless and as simple as I can, leaving me free to do the fun thing, being creative! ????
    Seriously, there should be something out there, but finding it or modding it for your needs is beyond my abilities.
    * Grazie
