Activity › Forums › Apple Final Cut Pro Legacy › Can’t Open 1 of 4 files from P2 Card. Serious Problem
  • Can’t Open 1 of 4 files from P2 Card. Serious Problem
    Posted by Bob Lampel on February 23, 2011 at 9:39 pm
    I performed a straight Log and Transfer from the P2 card to a drive but only 3 of the 4 files on the card transcoded into FCP. I also copied the contents of my card to a hard drive. When I try to bring it the copied MXF files to FCP via Log and Transfer, again only the first 3 clips move across. (There are over 3 gbs of media in the suspect file) Is there a utility or work-around to try and get this open?
    It’s possible, but not probable, that the file is from a previous session and didn’t get deleted along with everything else. If that’s the case, the Last.txt file that works for the 3 good files would be incorrect for the suspect file (since it’s left over from a previous session.) The real issue is that I am missing the first half of a spanned file and think this might be it. Can a file be opened without a last.txt file? Any ideas?
    Bob Lampel
    TV Director/Producer
    Sohrab Sandhu replied 15 years, 7 months ago 4 Members · 20 Replies
  • 20 Replies
  • Sohrab Sandhu
    February 23, 2011 at 10:55 pm
    Do you have the card?
    Was there a sudden interruption while recording? Maybe you need to repair that clip in camera before you can import it into fcp?
    2.66 GHz 8-core, ATI Radeon HD 4870,
    FCS 3, AJA Kona Lhi
    “The creative person wants to be a know-it-all. He wants to know about all kinds of things: ancient history, nineteenth-century mathematics, current manufacturing techniques, flower arranging, and hog futures. Because he never knows when these ideas might come together to form a new idea. It may happen six minutes later or six months, or six years down the road. But he has faith that it will happen.” — Carl Ally
  • Bob Lampel
    February 23, 2011 at 11:05 pm
    I have the card but the files were deleted. (They are what I copied to my hard drive.) Do you think it’s worth copying them back onto the P2 card and trying a repair?
    Bob Lampel
  • Sohrab Sandhu
    February 23, 2011 at 11:11 pm
    Hey Bob
    I have never tried this before (copying files back to card).
    Since you have already deleted the card, i guess you have no option but to copy the files back to card and see if the clip plays in the camera.
    FCS 3, AJA Kona Lhi
  • Bob Lampel
    February 23, 2011 at 11:21 pm
    I guess I have nothing to lose. BTW, there was no apparent interruption when I recorded the suspect file.
    Bob Lampel
  • Peter Tours
    February 23, 2011 at 11:33 pm
    Did you copy both the contents folder and the lastclip.txt to a new folder? You must do that or it won’t work.
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
  • Bob Lampel
    February 24, 2011 at 12:51 am
    I did. Like I said, three of four clips worked fine
    Bob Lampel
  • Jeremy Garchow
    February 24, 2011 at 1:09 am
    Are the clips spanned?
  • Bob Lampel
    February 24, 2011 at 1:34 am
    Yes. I have the second half of the spanned clip working fine.
    Bob Lampel
  • Jeremy Garchow
    February 24, 2011 at 2:02 am
    In the Log and transfer window, do you see three clips and one of them says (spanned)?
    Are you familiar with how p2 works?
  • Bob Lampel
    February 24, 2011 at 2:48 am
    It doesn’t. I’m reasonably familiar, if you’re asking if I know what spanned is. That said, I’m always up for any helpful info on anything P2 related.
    Bob Lampel
