Activity › Forums › VEGAS Pro › Can’t move video clips anymore!
  • Can’t move video clips anymore!
    Posted by José antonio De córdova on May 29, 2009 at 9:05 pm
    Hi, guys. Please, I need somebody’s help.
    I was working happily en Vegas until now. Today, when I launched the app, suddenly I cannot move the video clips that are in the timeline anymore. Each time I drag them with the mouse, they just bounce back to where they were… I’ve pressed every button on my keyboard, but nothing… I even uninstalled and reinstalled the program… Nothing.
    Any help before I throw myself out of the window?
    Thanks in advance.
    Joe
    Mike Kujbida replied 17 years, 3 months ago 3 Members · 4 Replies
  • Mike Kujbida
    May 29, 2009 at 9:37 pm
    Make sure Switches – Lock didn’t accidentally get enabled on the event.
    Right-click the event to check this out.
  • José antonio De córdova
    May 29, 2009 at 9:44 pm
    Thanks for your help! I already had checked that out. I think I found the culprit: an startup program was messing with the keyboard… I had to disable all of them one by one…
    Thanks again.
  • David Booth
    June 3, 2009 at 10:55 am
    Help! I am new to Sony Vegas Movie 8.0 .I have to put together a slideshow for my students for an end of the year awards ceremony. I have put the pictures in and created the show. However, it is to long. How can I reduce the time frame of each slide from 5 seconds to 3 seconds? I know you can do each one individually, but I have over 180 slides. Is there a setting to make them all 3 seconds long, without changing each one? Please respond ASAP!
  • Mike Kujbida
    June 3, 2009 at 1:44 pm
    David, first of all, it’s considered bad posting etiquette to come in on someone else’s thread. You’ll do much better by starting your own.
    Having said that, I do this all the time and the solution is quite easy.
    Click the first image to select it, go to the last image, Shift+click it and press the G key to Group everything together.
    Place the cursor at the end of the very last image, hold down the Ctrl key (you’ll see the symbol change from a rectangle to a rectangle with a ~ underneath it).
    Hold the Ctrl button down and drag the entire sequence backwards to the desired length.
    Told you it was easy 🙂
    For future reference, the length of your still images can be adjusted by going Options – Prefs -Editing and changing the time in the New still image length (seconds): box.
    Note that this is only for new additions, not what you already have on your timeline.
