Activity Forums Apple Final Cut Pro Legacy Can’t monitor output audio in log and capture
  • Can’t monitor output audio in log and capture
    Posted by Ian Dillon on June 22, 2010 at 9:05 pm
    I’m not a newbie, but I haven’t edited in a couple months, so I can’t remember how to make this work. Should be something simple that I’m forgetting.
    I have Decklink Extreme card and am trying to monitor the OUTPUT while in Log and Capture.
    I am getting audio input fine.
    I can hear my sequences playback fine.
    I have tried the little preview button in log and capture with no success, but don’t remember ever having to click that anyways.
    I have the FCP setting set to “playback Decklink Audio”.
    I have the system audio settings set to Decklink audio.
    HELP!!!
    Thanks in advance.
    Playroom Creative
    http://www.playroomcreative.com
    Ian Dillon replied 15 years, 10 months ago 2 Members · 2 Replies
  • Chad Brewer
    June 24, 2010 at 12:06 am
    Where are the analog outs from the Blackmagic card going?
    Also keep in mind if you’re capturing via firewire you won’t hear the audio going through the card while capturing because you’re not going through the card.
    Chad Brewer
    Senior Tape Operator/Engineer
    TeleVersions
  • Ian Dillon
    July 9, 2010 at 5:25 pm
    I FINALLY SOLVED THE PROBLEM!!!!!!!!!!!!!!!
    I disabled “Set Black Video Out To Deck When In Capture” in the Decklink control panel. It’s default is “on analogue out”. Since I am using a black burst generator already, I don’t use the default.
    Playroom Creative
