Activity › Forums › Adobe Premiere Pro › can’t monitor more than 2 tracks?
  • can’t monitor more than 2 tracks?
    Posted by Paul Dougherty on December 8, 2014 at 9:02 pm
    I have a sequence where I’m able to add audio tracks but can’t monitor more than 2, when I check the Seq settings it says Channel format & Number of Ch is says Stereo & 2 both greyed out (can’t change them) why?
    This seq was matching a 1080i ProRes Qt
    Paul
    Paul Dougherty replied 11 years, 9 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    December 9, 2014 at 11:45 pm
    You’re able to hear as many audio tracks as you have, the final mix buss for the sequence is just in stereo.
    If you, say, want 5.1 monitoring and have the hardware to monitor it properly then you would set:
    Number of audio tracks: 1
    Channel format: 5.1
    If you need an arbitrary number of channels and, again, have the hardware to monitor such as discrete channels (or need channels for broadcast output)
    Number of audio tracks: 8 (example)
    Channel Format: Mono
    You may need to go to preferences > Audio hardware and adjust/assign settings as needed.
    You cannot mix channel formats (have a track of stereo with a track of 5.1). You would have to mux your delivered file after the fact in something like FFMPEG or Squeeze or another broadcast encoder.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Paul Dougherty
    December 10, 2014 at 12:14 am
    Thanks Angelo,
    I will not be in front of the system for a few days to act on your advise but I appreciate it
    Best,
    Paul
