Activity Forums Media 100 Can’t Master to Tape!!!
  • Can’t Master to Tape!!!
    Posted by Michael Leach on July 13, 2005 at 3:35 pm
    I am trying to master to tape and i keep getting a message that says “Could not complete the “Master to Tape….” command b-cuz there is not enough memory. Try giving the application more memory in its “Get Info” window”. I still wet behind the ears a bit with Media 100…. but i looked all over for a ‘Get Info” with no luck. So i am turning to the masters. Thanks in adavnce.
    Michael Leach replied 21 years, 2 months ago 2 Members · 2 Replies
  • Floh Peters
    July 13, 2005 at 3:54 pm
    Which version of Media 100 and which OS are you using? The memory management is only available under OS9. When do you get the error message? When opening the master to tape window? Have you tried copying your clips (or parts of your clips) from your timeline into a new timeline and to master this to tape?
  • Michael Leach
    July 13, 2005 at 9:00 pm
    I am working on OSX and Media 100 i Ver 8.2.2. I get the error message with a try to master to tape. Whats crazy about it is…. i was mastering lots of spots to my file tapes and then on the last one i get that message. i have tried the copy into new timeline… thats always my first move. I am still getting use to Media 100…. at times i love and then at times i hate. I am coming from a Final Cut backgroud so at times i feel limited in what i can do in my base editor. Any tips or tricks would be welcomed. thanks
