Activity › Forums › Avid Media Composer › Cant import .wav getting exception disk_invalid_filename_syntax
Posted by Ross Byron boughton on July 31, 2012 at 6:19 pmam using MC 5.5 on a mac
i have the video files in however i cant get the .wav files files to import
tiaRoss Byron Boughton
Editor / Webmaster / Sound Designer
https://www.inch.com/~bellevue/Ross Byron boughton replied 14 years, 1 month ago 2 Members · 5 Replies -
Richard Sanchez
July 31, 2012 at 6:29 pmDo your filenames have illegal characters? Exclamation points, commas, periods, and especially slashes are a no no.
Richard Sanchez
Los Angeles, CA“We are the facilitators of our own creative evolution.” – Bill Hicks
Ross Byron boughton
July 31, 2012 at 6:50 pmT13.wav
T08.wavpretty straight up rec by soundman to a card then i put the contents of the card with the file projects
i know i am missing something tiny 24bit 48 k
thanks RBRoss Byron Boughton
https://www.inch.com/~bellevue/ -
Richard Sanchez
July 31, 2012 at 7:00 pmWhat about the file path that your clips are in? I’ve seen the Avid give that error if, for example you files are in a folder called “7/31”. There’s a slash in the name and that will trip up the Avid.
Richard Sanchez
Ross Byron boughton
August 1, 2012 at 12:32 ami bet that’s it when i get back to work in the morn will check it out
fingers crossed
thanks and then post thanks richRoss Byron Boughton
Ross Byron boughton
August 2, 2012 at 2:02 pmyes rich thats what it was i had the .wavs in a project folder with a long name and dates IE 7/20/24
best Ross bRoss Byron Boughton
