Activity › Forums › Adobe After Effects › Can’t import uncompressed UYVY AVI footage into AFX7
  • Can’t import uncompressed UYVY AVI footage into AFX7
    Posted by Travis Fadler on February 16, 2006 at 9:52 pm
    I recently installed 7.O on a hp xw8200 and get an error message when importing a 30sec uncompressed(UYVY)AVI file. No problems on 6.5. Any suggestions?
    John Baum replied 20 years, 7 months ago 3 Members · 3 Replies
  • Realethan
    February 17, 2006 at 3:47 am
    What’s the error message
  • Travis Fadler
    February 17, 2006 at 4:31 pm
    It crashes, says “after effects can’t continue:sorry,after effects has crashed (0 ::42)”
  • John Baum
    February 17, 2006 at 6:13 pm
    One reason you would get this is if you have a Decklink capture card. It is a known bug and a fix should be available soon. The only workaround at the moment is to capture aa something other then 8bit avi. 10bit will work fine.
