Activity Forums Apple Final Cut Pro Legacy Can’t import QT file
  • Can’t import QT file
    Posted by Tim Silva on January 28, 2011 at 4:44 pm
    A client gave me a movie clip generated with a KODAK Zi8 Pocket Video Camera. The codec is apparently Ambarella AVC encoder, 1280 x 720, 59.94. Quicktime plays the file without any trouble. FCP 6.0.6 won’t import the file – wrong file type or some such nonsense. I’ve tried converting the clip to H.264 and Apple Pro Res. Same problem. I’ve changed the permissions on the file to make sure that wasn’t the issue. I’m stumped. Any thoughts?
    Thanks – Tim
    Tim Silva replied 15 years, 7 months ago 5 Members · 14 Replies
  • 14 Replies
  • Rafael Amador
    January 28, 2011 at 4:53 pm
    [Tim Silva] “FCP 6.0.6 won’t import the file – wrong file type or some such nonsense. “
    There is a list of supported FC codecs.
    FC is a video editing tool. Those are delivery codecs; no for editing.
    [Tim Silva] “I’ve tried converting the clip to H.264 “
    Bad choice. Another non supported codec.
    Use MPGStreamclip to convert your movie to Prores.
    rafael
    http://www.nagavideo.com
  • Tim Silva
    January 28, 2011 at 5:01 pm
    Already converted to ProRes. Didn’t work.
  • Michael Kammes
    January 28, 2011 at 5:43 pm
    Once converted to Pro Res, does the file play at the OS level?
    If you can play the raw AVC file at the OS level, have you tried using QT to do the conversion to Pro res? (Since you have FCP, the Pro ability is built into QT 7).
    ~Michael
    .: michael kammes mpse
    .: senior applications editor . post workflow consultant
    .: audio specialist . act fcp . acsr
    .: michaelkammes.com
    Hear me pontificate: Speaking Schedule .
  • Rafael Amador
    January 28, 2011 at 5:50 pm
    [Tim Silva] “Already converted to ProRes. Didn’t work.”
    With MPGStreamclip?
    rafael
  • Jeremy Garchow
    January 28, 2011 at 6:11 pm
    If it’s AVC, have you tried log and transfer?
  • Tim Silva
    January 28, 2011 at 6:26 pm
    Yes, I used QT to make the ProRes version and that didn’t work.
  • Tim Silva
    January 28, 2011 at 6:27 pm
    I have not tried the conversion with MPGDStreamclip. Would that make a difference?
  • Tim Silva
    I have not tried Log and Transfer but will.
  • Tim Silva
    January 28, 2011 at 6:31 pm
    I can’t get the file into FCP for Log and Capture.
  • Jeremy Garchow
    January 28, 2011 at 6:34 pm
    Please post a screen grab of what the file structure looks like.
