Activity › Forums › Adobe Premiere Pro › Can’t import mpeg’s that AME CC itself rendered?!
  • Can’t import mpeg’s that AME CC itself rendered?!
    Posted by Tudor “ted” jelescu on June 9, 2014 at 8:48 am
    So I started having this problem with the latest Premiere CC version- I render using AME CC a normal mpeg, like I did many times before, and Premiere will not read it back. I also started having this issue with mpeg clips rendered in 5.5 or 6. Any one experiencing the same?
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Tudor “ted” jelescu replied 12 years, 3 months ago 2 Members · 2 Replies
  • Kevin Monahan
    June 9, 2014 at 9:16 pm
    Ted,
    Sign out from Creative Cloud, then sign back in. See if that helps.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Tudor “ted” jelescu
    June 10, 2014 at 6:39 am
    This is weird- did not sign out or re-start, I worked in CS 55, then opened CC again and even if this happened several times before (could not import mpeg files that were rendered from PPro CC in AME CC) this time it worked… So I suggest as a fix these steps:
    Post on the COW
    Get Kevin to answer you
    Re-start Premiere CC and voila, it works 😀
    Tudor “Ted” Jelescu
    Senior VFX Artist
