Activity › Forums › Avid Media Composer › Can’t import HDV
Can’t import HDV
Posted by Nate Whited on May 12, 2008 at 6:41 pmI have AXP latest version, quad-core mac, and I cannot capture footage shot in HDV. I always get a warning that says “Exception: Video signal present but not captured.”
I have had NOTHING but trouble with AXP but I am stuck with it until budgetary room opens up after June 1.
Nate Whited replied 17 years, 10 months ago 3 Members · 13 Replies -
Jon Zanone
May 14, 2008 at 11:38 amAre you running the correct OS? Quicktime? What deck are you using?
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better” -
Nate Whited
May 14, 2008 at 9:03 pmI should point out that the video appears in my composer window as it should. I can mark in and out points in my capture tool just like any other tape. I can fast forward rewind and watch he HDV video on my monitor just fine. But when I try to capture I get the same error message every time.
Jon Zanone
May 15, 2008 at 12:47 amCheck your system specs according to the matrix from Avid. You say you are using QT 7.3.1, but that’s not qualified even for the latest version (5.8.3). Belive me, even a X.X.1 release of Qucktime can cause problems. Make sure you are running the correct OS as well.
Jon
Nate Whited
May 15, 2008 at 1:25 pmI have been all over Apple’s website. I have found 6.5.2, 6.5.3, 7.1.6, 7.2, and then it jumps to 7.3.1–which is what I have. Is there someplace I haven’t found yet that has 7.3 available for download?
Jon Zanone
May 16, 2008 at 11:42 amTry here
(https://www.tucows.com/preview/195040)
Jon
Nate Whited
May 16, 2008 at 1:03 pmum…..no.
I go to that link, click “download” and get this:
The page you tried was not found. You may have used an outdated link or may have typed the address (URL) incorrectly. You might find what you’re looking for in one of these areas:
Underneath that is another “download quicktime” link, and when you hit that it takes you to the QT 7.4.5 download page.
Nate Whited
May 16, 2008 at 2:14 pmOkay, I found QT 7.3 here:
https://community.avid.com/forums/t/44210.aspx
I used Pacifist to remove 7.3.1 and replaced with 7.3. I now have the EXACT version of QT installed required by avid. I restarted my mac, opened my project, opened my capture tool loaded the HDV tape and attempted to capture a clip.
“EXCEPTION: Video signal present but not captured.”
Jon Zanone
May 17, 2008 at 3:43 amOK, lets start with the basics: What OS are you running? What video card? Have you been able to digitize anything?
Jon
Nate Whited
May 19, 2008 at 4:42 pmI’ve had this system since September and it has captured DVcam–although not as smoothly as my old Meridian system.
I’m using OS 10.4.11, QT 7.0, card is a NVIDIA GeForce 7300 GT. Project setting is set to 1080i/59.95 HDV….according to the Manual everything is set the way it should be. Like I said I have deck control, I can see the video just fine in my composer window. It seems to be doing exactly what it is supposed to be doing–until I ask it to capture.
