Activity Forums Avid Media Composer Can’t import HDV
  • Jon Zanone
    May 20, 2008 at 12:05 pm
    My bet is the problems you are having is because your deck is not on the supported devices list HERE. Do you have access to a different HDV deck?
    If you can’t get to this link, let me know and I’ll send you a pdf.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Ulrike Kofler
    October 26, 2008 at 1:02 pm
    did you maybe find out how to cature hdv? i have exactly the same problem…Thank you. Ul
  • Nate Whited
    October 27, 2008 at 2:47 pm
    I first have to make sure there are no other projects open, then create a new project in HDV. I then have to quit avid and go into he menu on my tape deck and manually select HDV. (If left in “auto” mode the deck is supposed to know what type of format is inserted, but it doesn’t) Once I get my deck set to HDV I then have to start my Avid and go directly to the HDV project I created.
    Mixing HDV and DV is very troublesome. Be prepared for numerous crashes.
Page 2 of 2
