Activity › Forums › Adobe Encore DVD › Can’t import H.264
Can’t import H.264
Posted by Alex Kogan on October 15, 2007 at 4:21 pmI have an H.264 file that I created using Procoder 3.0 that I’m trying to import into Encore and it’s not letting me import it. It shows up gray and unimportable when I go to import it. Anybody have any idea?
Alex
Tony Bartolucci replied 18 years, 9 months ago 3 Members · 16 Replies -
Joe Bowden
October 15, 2007 at 5:31 pmPlease provide more detail about the file: its extension, encoding parameters, etc.
Alex Kogan
October 15, 2007 at 7:20 pmThe file is an .h264. I’m on an apple and in the finder it says it’s a Unix Executable file. The paramaters I set in Procoder were pretty basic and I tried it as a raw H.264 and using an MPEG stream.
Joe Bowden
October 15, 2007 at 7:52 pmTry setting the extension to .mp4.
If it still doesn’t import, or has to be re-transcoded, I would suggest more details on encode settings from Procoder.
Alex Kogan
October 15, 2007 at 9:17 pmIt didn’t open still, so here are the settings from Procoder:
Stream Type: I tried both MPEG 2 Stream and Raw H.264
Video PID 2064
Audio PID 2068Profile High
Livel 4.1
Size of Coded Video 33
Number of B-Pict 2
1280×720
16:9
Non-Interlaced
CBR 1 Pass
Bitrate 8000 KBPS
Reference Frames: 4
Search Shape 8×8
Entropey Code CABAC
All Checked:
Uses Fast inter and intra decision
Uses Hadamard TransferMotion Estimation: Quarter Pixel
Checked:
Write Timestamp
Write Acces Unit Delimiters
Write Sequence end codeThat’s all. Thanks a lot.
Alex
Joe Bowden
October 15, 2007 at 9:40 pmI assume you were able to select the file in the Import dialog, but it failed to import.
Was there an error dialog of any kind?
Alex Kogan
October 16, 2007 at 12:33 amActually, I can’t even get it to try and import. When I go to select it in import, either as an asset or timeline, it shows up as gray (unselectable). In the finder, it says it’s a unix executable file. Very, very weird to me.
