Activity › Forums › Boris FX Particle Illusion › can’t import avi in particle illusion
Posted by Romain Borges on April 24, 2008 at 1:14 amI’m just start with particle. when i want import avi video into the layer the screen stay blank but there is the avi’s names on the layer but the movie don’t appear.but when I import jpg or other picture there is no probleme.what’s the solution please.
Romain Borges replied 18 years, 5 months ago 3 Members · 11 Replies -
Aharon Rabinowitz
April 24, 2008 at 1:31 pmRead this and see if it helps:
https://forums.creativecow.net/thread/23/859598#859653
Aharon Rabinowitz
Email: arabinowitz (AT) yahoo (DOT) com
All Bets Are Off Productions, Inc.
Creative Cow After Effect Podcast
Internet Killed the Video Star: A Guide to Creating Video for the Web -
Romain Borges
April 24, 2008 at 3:33 pmthat’s not change .there’s the same probleme.but my is just with video not with other files.
Aharon Rabinowitz
April 24, 2008 at 4:14 pmthe other possibility is that your avi is using a video codec pillusion doesn’t understand.
What kind of AVI are you trying to import. If DV-AVI, try something else. Just as a test, try a short uncompressed AVI, or a an AVI with Cinepack or some other compression codec.
Aharon Rabinowitz
Romain Borges
April 25, 2008 at 12:12 amthanks for you support!! for import video i must have uncompressed files.but it’s strange because when i have this problem (yesterday.sorry for my bad english…)i’m already test uncompressed files (save with after effects) and today i test with uncompressed video (save with vegas) and it’s ok.but i don’t understand why there’s a problem with uncompressed files save with after effects but no with uncompressed files save with vegas.
can i have do something for can import avi dv files? -
Alan Lorence
April 25, 2008 at 1:47 pmDon’t use uncompressed. Not only does particleIllusion have problems with it under some unknown conditions for some people (like you’ve seen), but it’s a waste of HD space.
Use a lossless codec like huffyuv or Lagarith. They result in perfect (“lossless”) image quality (identical to uncompressed) but result in much smaller file sizes, use less bandwidth when transferring (during playback for instance), and most importantly: always work in particleIllusion.
And for those of you who say “I don’t want to use *any* compression on my video because I want the best quality” — “lossless” compression *is* the best quality. Have you ever zipped a data file? That’s lossless compression — the file after zipping and unzipping is exactly the same as the original file.
Alan.
Aharon Rabinowitz
April 25, 2008 at 1:56 pmYeah – my advice was to TEST with uncompressed video. Not to use it. The goal was to see if the problem was related to codec or not.
Aharon Rabinowitz
Alan Lorence
April 25, 2008 at 2:34 pmSorry — didn’t read your post very carefully. Or while fully awake. Or at all.
Alan.
Romain Borges
April 25, 2008 at 4:10 pmI have an another question.i’ve install k-lite codec pack with the huffyuv & Lagarith but when i want export in AE there isn’t render option with the two codec.what i must configure for i can can export ?
Aharon Rabinowitz
April 25, 2008 at 4:24 pmdon’t export from AE – Render. Choose composition > Make Movie, and then set it up in the output module.
Aharon Rabinowitz
