Cant import a VC-1 m2ts file.
I’m haveing problems importing an m2ts file, it’s a blu-ray ripp from Blade runner and I believe it uses VC-1 codec.
AFX just says it’s an unsupported file format?
I may be able to use a convertor to change it’s format to an AVI or Mpeg2 file but I wanted to do that in AFX, the problem is these convertors are usualy lossy, and I need to keep the image quality, hence my use of HD source footage in the first place.
Are these kinds of m2ts files not supported by AFX, I’ve looked for a VC-1 Codec but I can only find the odd refference to them here and there.
Richie.
