Activity Forums DaVinci Resolve Can’t import a large file into Resolve Studio 20
  • Can’t import a large file into Resolve Studio 20
    Posted by Sibel Zivy on May 31, 2025 at 6:51 am
    So right off the bat, I hate working with proxies unless I’ll add lots of graphics, so please don’t suggest that route first.
    Alright, so after spending a few days playing with codecs to find the optimal size-to-quality ratio, I’m satisfied with my .mkv VBTQ that allowed me to record 5 hours and 40 minutes of crisp 1440p/60fps gameplay with a file size of 110 GB.
    But now I can’t import it into Resolve; Initially, the file was on a separate drive, so I copied it to the main OS/Apps drive because I understand editing software works on a “copy”, and I assumed that was the caveat, hence two different drives with the cache load and all of such a large file..
    But no, it simply won’t load the file in, even when using the in-app media storage browser, the file doesn’t show, and it’s breaking my heart.
    Info for Reference:
    32Gb ram (6000mhz/DDR5)/2tbNvme/3080ti (12gb/1.67Ghz/10,000+ cuda cores)/73800X3D(8 cores- 16 threads)
    Sibel Zivy replied 1 year, 3 months ago 3 Members · 3 Replies
    May 31, 2025 at 1:51 pm
    Hey Sibel,
    It sounds like you have done everything right, and taken great care to do so.
    Like you, I hate proxies if they can be avoided. But most of my work is on the master, rather than the off-line, so I rarely have that problem.
    Out of interest, have you tried to import the MKV file into Davinci Studio v19?
    I found this recent article, that may just give you the solution.
    https://beginnersapproach.com/davinci-resolve-mkv/
    Basic one, which I often used back in the day, is to check what happens if you rename the file format to MP4 or similar?
    Just a word of caution, as this may cause trouble later + at over 5 hours of recording, there is every chance that your timecode will slip.
  • Eric Santiago
    June 5, 2025 at 3:36 pm
    Any updates to this issue.
    Asking for a friend…
  • Sibel Zivy
    June 9, 2025 at 3:18 pm
    Thank you, Mads,
    Apologies for my late reply.
    I used OBS’s remux feature (located under File -> Remux recordings), which worked well. Managed to FF at x4 with no hiccups (but I noticed some at 8x, but hey, with the file I’ve got, I’m not complaining!), which I was worried about with the .mp4, being a compressed format.
    And I just tried your advice regarding version 19, sadly, it didn’t work either.
    Anyways, cheers!
