Activity Forums VEGAS Pro Can’t import 10 bit .mov file into vegas 12 why?
  • Can’t import 10 bit .mov file into vegas 12 why?
    Posted by Shawn Bossick on June 4, 2013 at 8:54 pm
    Hello all!
    I have Vegas Pro 12. I just had a file delivered to me that is a 10 bit uncompressed .mov file & Vegas cannot open it. It imports the audio but tells me there is no video there. However After Effects CS5 open’s & plays the file fine. I do have QuickTime Pro installed. Does anyone know why Vegas cannot open it ? Is there something I need to install to have Vegas read this file ? I found out that the codec is integer (Big Endian) If I can find this codec ? Will Vegas then play the file ? I am currently looking for the codec but have not found it yet ? Will windows 7 64 bit work with this codec ?
    Am I doomed ? Or is there hope ?
    Thank you in advance!
    Shawn.
    Shawn Bossick replied 13 years, 3 months ago 3 Members · 3 Replies
  • Steve Rhoden
    June 5, 2013 at 10:28 am
    This happens to me at times, because i get media from a wide
    client base, giving me an endless variety of video formats and
    flavors…. So as in your situation, instead of hunting all
    over for the right codec, i simply render out everything thru
    after effects in a vegas compatible format and then start my
    editing back in Vegas. Im hoping that file you have isnt
    way too long.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Norman Black
    June 5, 2013 at 2:57 pm
    If QT pro can handle the file, QT pro can probably convert the file to a QT codec that Vegas can handle. Otherwise some other program to convert will be necessary. AE is an option since you have it.
  • Shawn Bossick
    June 5, 2013 at 6:09 pm
    Thanks guys!!
    Got it.
