Activity Forums Boris FX can’t get still images to finish keyframe
  • can’t get still images to finish keyframe
    Posted by Chrisusvi on June 3, 2005 at 6:37 pm
    I am trying to do a simple animation with 2 boxes twirling in for 8 seconds and then tumble out of the screen. I got them to begin the journey but the problem is when I try to make a keyframe on the last frame and set the image off the screen so it would follow that path. It doesn’t make the motion from the keyframe that I designated. I tried it several times but nothing happens. I think I’m doing the procedure correctly.
    The images were created in Photoshop and masked with an alpha channel and imported into Boris RED and I made a spline primitive because I wanted to give the 2D object an extrusion.
    If there is a better and easier way to do this it would be quite appreciated.
    Chrisusvi replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
