Activity Forums Adobe After Effects Expressions Can’t get Source Text parameter to execute 2 expressions.
  • Can’t get Source Text parameter to execute 2 expressions.
    Posted by Daniel Annefelt on October 5, 2020 at 7:37 pm
    Hello genius people!
    Running AE 17.1.4 with JavaScript enabled,
    I have two simple expressions on the Source Text parameter.
    The first expression retrieves text input from another layer in a separate Comp.
    ______
    comp(“CHANGE TEXT”).layer(“1 Line Small Text”).text.sourceText
    ______
    The second expression changes between two fonts of the text based on a Expressions Checkbox effect.
    ______
    if (comp(“CHANGE TEXT”).layer(“Layout_Selector”).effect(“Comedy Central”)(“Checkbox”) == 1)
    (text.sourceText.style.setFont(“AmericanTypewriter”))
    else
    (text.sourceText.style.setFont(“Helvetica”))
    ______
    Each expression works like a charm when using one or the other.
    But when combined – with is my goal – it stops retrieving the text from the other layer.
    ______
    else
    ______
    Obviously there is some syntax missing that tells the Source Text to do two things
    – get text from another layer and check what font to use based on the checkbox.
    But my merger expressions skills can’t crack this.
    Does anyone have a solution to this or is a current AE cc2020 limitation
    cheers!
    .::D
    Daniel Annefelt replied 5 years, 11 months ago 2 Members · 2 Replies
  • Stephen Dixon
    October 6, 2020 at 2:15 am
    You need to store the sourceText in a variable, and apply the style changes to that variable. So:
    let st = comp(“CHANGE TEXT”).layer(“1 Line Small Text”).text.sourceText;
    if (comp(“CHANGE TEXT”).layer(“Layout_Selector”).effect(“Comedy Central”(“Checkbox”) == 1){
    st.style.setFont(“AmericanTypewriter”)
    } else {
    st.style.setFont(“Helvetica”)
    st
  • Daniel Annefelt
    October 6, 2020 at 9:05 am
    Thanx!
    .::D
