Activity › Forums › Broadcasting › Can’t get SONY broadcast monitor crisp
  • Can’t get SONY broadcast monitor crisp
    Posted by Alex Delany on September 2, 2010 at 9:55 pm
    I just connected this great little monitor to my tower at work and I can’t seem to find any settings that prevent it from being fuzzy. It seems as though the resolution is off but I can’t fix it.
    The monitor = sony lmd-2451w
    (https://pro.sony.com/bbsc/ssr/cat-monitors/cat-videoproduction/product-LMD2451W/)
    It’s connected to my Mac tower via DVI (not DVI-D) and the resolution on both the monitor and the control panel is 1920 x 1200 @ 60hz (NTSC Television).
    Please help!
    Alex D.
    Alex Delany replied 16 years ago 3 Members · 3 Replies
  • Gary Hazen
    September 2, 2010 at 11:10 pm
    This isn’t NTSC or any other flavor of TV for that matter.
    Get a proper video card for your Mac. Decklink or Kona.
    Get the SDI module for the monitor
    https://pro.sony.com/bbsc/ssr/product-BKM243HS/
    Plug it in. Done.
  • Shane Ross
    September 4, 2010 at 1:19 am
    It isn’t sharp and clear because you are sending it a computer signal, not a broadcast signal. You are sending a non-standard frame size…and an RGB signal, not YUV. It won’t look sharp unless you feed it a signal with an HD Capture card. AJA, Matrox, Decklink…
    Shane
  • Alex Delany
    September 15, 2010 at 3:44 pm
    Thank you!
    Alex D.
