Can’t get SD output working within FCP on Kona LHe
Hi there,
I run FCP Studio 2 in conjunction with a Kona LHe and recently for some reason my SD output won’t work. Within FCP I can view HD footage fine on the monitor but whenever I switch to SD footage I just get a still on my external monitor. I can playback the footage fine through AJA TV so I’m guessing it might be something to do with FCP. It is set to All frames on the video output tool so I can’t understand why. Also, the Kona Control Panel is set to PAL 625 too. Any ideas?
