Activity Forums VEGAS Pro cant get rid of black vertical bar on right side of preview and rendered output
  • cant get rid of black vertical bar on right side of preview and rendered output
    Posted by Dave Smith on July 29, 2008 at 5:46 am
    When I drag any of my captured video onto my time line in any version of Vegas (currently using Vegas Pro 8) and look at it in the preview window there is a vertical black bar 2-3 pixels wide along the right side of the preview and this same black bar is there when I render the video to 720×480, 640×480, or even 360×240, even if I choose the option to stretch the output to fill the frame when I render. However, the captured .avi files do not have a black stripe when I view them in quicktime outside of Sony – they are just a regular 720×480 video, no problem.
    The only way I seem to be able to get rid of the black empty space on the right side of the video in Vegas is to use the event pan/crop and zoom in slightly on each video to around 712×475, but this makes the render take forever when I do it to every video in the project, and I shouldn’t have to do it. I notice that if I go into pan/crop and just move the frame a few pixels to the left, the bar goes away but then I have a black bar on the left side due to the frame being outside the video.
    I had this same problem on earlier versions of Vegas and still have it with a new install of Vegas 8 pro on a brand new install of WinXP. I have all defaults set for Vegas 8 and capture the video using the Vegas capture utility included with Vegas 8 via Firewire from 2 different standard def camcorders, a Panasonic and a Sony, capturing 720×480 frame size at 29.97 fps.
    PLEASE help as this does not seem to be an issue for me with the captured video and does not seem to be a problem with my camcorders, but something inside of vegas. Perhaps I hit a shortcut key that changed some setting by accident as I was editing but it seems like this has been the case as long as I’ve been using Vegas, and I really don’t want to use another editor, but can’t just put up with this issue that my friends that use other editors have never seen and can’t fix for me.
    Dave Smith replied 18 years, 1 month ago 1 Member · 1 Reply
