Activity Forums Media 100 Can’t get M100 Suite 2.1 to Open. Need h-e-l-p right away!
  • Can’t get M100 Suite 2.1 to Open. Need h-e-l-p right away!
    Posted by Marcus Warren on September 7, 2013 at 11:24 pm
    I am unable to get M100 to open. The start-up screen comes up for a few seconds and then I get the Promlem Report for Media 100 Suite. I need to finish and edit tonight so any help is appreciated. I’m running MacOSX 10.6.8 on a MacBook Pro with 4GB RAM. The only thing different that I have done to the computer is copy of of the download files to an external HD and delete the files from the MBP a couple of days ago. When I tried to start M100 today, it would not come up as mentioned above. M100 had been working well up until this point. Below is the error report:
    Process: Media 100 Suite [252]
    Path: /CONTENTcreation/Media 100 Suite Folder/Media 100 Suite.app/Contents/MacOS/Media 100 Suite
    Identifier: com.Media100.Media100Suite
    Version: 2.1 (2.1)
    Code Type: X86 (Native)
    Parent Process: launchd [105]
    Date/Time: 2013-09-07 18:14:56.476 -0500
    OS Version: Mac OS X 10.6.8 (10K549)
    Report Version: 6
    Interval Since Last Report: 123814 sec
    Crashes Since Last Report: 29
    Per-App Interval Since Last Report: 11288 sec
    Per-App Crashes Since Last Report: 21
    Anonymous UUID: 6D7FBCBE-9019-4857-998E-188B0F37C8F3
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 libSystem.B.dylib 0x02298474 pthread_mutex_lock + 24
    1 …Media100.Embedded.framework 0x1f407ff6 BE_Mutex::Lock() + 32
    2 …Media100.Embedded.framework 0x1f4488cf BE_Allocate(long, unsigned char) + 166
    3 …Media100.Embedded.framework 0x1f453f14 BM_AllocBuffer(E_Allocate_How*, unsigned long*, long, char**) + 81
    4 …Media100.Embedded.framework 0x1f45406d BM_AllocPoolOrHeap(E_Allocate_How, unsigned long, long, long, PH_Header**) + 53
    5 …Media100.Embedded.framework 0x1f45084a BM_CreateHeap(E_Allocate_How, unsigned long, long, short, long, heapStruct**) + 320
    6 …Media100.Embedded.framework 0x1f449f30 RT_Init() + 133
    7 …Media100.Embedded.framework 0x1f4e2342 VF_Perform_Fragment_Startup_Task(Init_Struct*) + 91
    8 …Media100.Embedded.framework 0x1f464da2 HAL_Initialize + 36
    9 …Media100.Embedded.framework 0x1f46528a Do_Init + 543
    10 …Media100.Embedded.framework 0x1f46f5de HAL_Init + 24
    11 com.Media100.Media100Suite 0x00498dcd HAL_Init + 130
    12 com.Media100.Media100Suite 0x002f3615 THAL::Initialize(unsigned char&) + 213
    13 com.Media100.Media100Suite 0x002f2f97 THAL::CheckHALStatus(unsigned char) + 81
    14 com.Media100.Media100Suite 0x0004b25b main + 315
    15 com.Media100.Media100Suite 0x00045ca1 start + 53
    Thread 1: Dispatch queue: com.apple.libdispatch-manager
    0 libSystem.B.dylib 0x022b9382 kevent + 10
    1 libSystem.B.dylib 0x022b9a9c _dispatch_mgr_invoke + 215
    2 libSystem.B.dylib 0x022b8f59 _dispatch_queue_invoke + 163
    3 libSystem.B.dylib 0x022b8cfe _dispatch_worker_thread2 + 240
    4 libSystem.B.dylib 0x022b8781 _pthread_wqthread + 390
    5 libSystem.B.dylib 0x022b85c6 start_wqthread + 30
    Thread 2:
    0 libSystem.B.dylib 0x022b8412 __workq_kernreturn + 10
    1 libSystem.B.dylib 0x022b89a8 _pthread_wqthread + 941
    2 libSystem.B.dylib 0x022b85c6 start_wqthread + 30
    Thread 3:
    0 libSystem.B.dylib 0x022c0aa2 __semwait_signal + 10
    1 libSystem.B.dylib 0x022ec9c5 nanosleep$UNIX2003 + 188
    2 libSystem.B.dylib 0x022ec903 usleep$UNIX2003 + 61
    3 …Media100.Embedded.framework 0x1f4d09aa XF_Set_Thread_Priority(long, unsigned char) + 30
    4 …Media100.Embedded.framework 0x1f44bd07 TE_Set_Thread_Priority(long) + 49
    5 …Media100.Embedded.framework 0x1f44aa97 Thread_Farm::Thread_Farm_Main(Thread_Farm_Task_Info*) + 29
    6 …Media100.Embedded.framework 0x1f44a9c6 Thread_Farm::Work_Thread_Runner(void*) + 24
    7 …ple.CoreServices.CarbonCore 0x024e754a PrivateMPEntryPoint + 68
    8 libSystem.B.dylib 0x022c0259 _pthread_start + 345
    9 libSystem.B.dylib 0x022c00de thread_start + 34
    Thread 4:
    Thread 5:
    Thread 6:
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x00000008 ebx: 0x02298470 ecx: 0x00000001 edx: 0x00000000
    edi: 0xbffff3ec esi: 0x00000008 ebp: 0xbffff2f8 esp: 0xbffff2c0
    ss: 0x0000001f efl: 0x00010286 eip: 0x02298474 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x00000008
    Binary Images:
    0x1000 – 0xc4dfef +com.Media100.Media100Suite 2.1 (2.1) <9A214B4B-AF9E-BCEF-56FE-DF50F34B084F> /CONTENTcreation/Media 100 Suite Folder/Media 100 Suite.app/Contents/MacOS/Media 100 Suite
    0x1247000 – 0x1247ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x124f000 – 0x13cafe7 com.apple.CoreFoundation 6.6.6 (550.44) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x14c2000 – 0x14c2ff7 com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x14c5000 – 0x14c5ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x14cd000 – 0x17c7fef com.apple.QuickTime 7.6.6 (1790) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x1873000 – 0x1881ff7 com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x1889000 – 0x1890ff7 com.apple.agl 3.0.12 (AGL-3.0.12) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x1897000 – 0x1997fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
    0x19bb000 – 0x1a18ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x1a38000 – 0x1b6bffb +libCFHDDecoder.dylib ??? (???) /Library/Application Support/CineForm/Libs/libCFHDDecoder.dylib
    0x1c2a000 – 0x1d5afef +libCFHDEncoder.dylib ??? (???) /Library/Application Support/CineForm/Libs/libCFHDEncoder.dylib
    0x1e30000 – 0x2096ff7 com.apple.security 6.1.2 (55002) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x2173000 – 0x21b0ff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x21cd000 – 0x2237fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
    0x2292000 – 0x2439ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
    0x24bb000 – 0x24befe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x24c1000 – 0x27e1ff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x2857000 – 0x2903fe7 com.apple.CFNetwork 454.12.4 (454.12.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x2968000 – 0x29acfe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x29d3000 – 0x2a9efef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x2afd000 – 0x2b7dfeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x2bb1000 – 0x2be4ff7 com.apple.AE 496.5 (496.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x2bfc000 – 0x2c99fe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x2cd8000 – 0x2cfeffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x2d14000 – 0x2e96fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
    0x2ef8000 – 0x2f01ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x2f0b000 – 0x2f1ffe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
    0x2f28000 – 0x2f35ff7 com.apple.NetFS 3.2.2 (3.2.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x2f3e000 – 0x2febfe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
    0x2fff000 – 0x300dfe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
    0x3012000 – 0x301eff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
    0x3022000 – 0x3068ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
    0x3075000 – 0x312efe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
    0x313c000 – 0x3164ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) /usr/lib/libxslt.1.dylib
    0x316f000 – 0x3179fe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x3181000 – 0x3187fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x318f000 – 0x3192ffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x3197000 – 0x34bbfef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x35fb000 – 0x365fffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x3681000 – 0x3696fff com.apple.ImageCapture 6.1 (6.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x36ac000 – 0x375aff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x3784000 – 0x37c7ff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x37f0000 – 0x380cfe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x381c000 – 0x381eff7 com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x3823000 – 0x382dffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x3836000 – 0x38b0fff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x38e2000 – 0x3b53fef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x3c61000 – 0x4450557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x4518000 – 0x46dbfeb com.apple.ImageIO.framework 3.0.5 (3.0.5) <87750C2B-193F-56A6-AB97-0842A2D02092> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x473a000 – 0x479bfe7 com.apple.CoreText 151.12 (???) <98F53C15-1D29-A2B3-0717-5A26A2699163> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x47d3000 – 0x486efe7 com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x4895000 – 0x4951fff com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x4988000 – 0x49dbff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x4a06000 – 0x4a17ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x4a24000 – 0x4accffb com.apple.QD 3.36 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x4af9000 – 0x4b0dffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x4b1b000 – 0x4b1bff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x4b1e000 – 0x4b6dfe7 libTIFF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x4b79000 – 0x4b7dff7 libGIF.dylib ??? (???) <5D29E5F4-30B9-5A24-55E7-BCBA30499093> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x4b82000 – 0x4ba0fe7 libPng.dylib ??? (???) <45185287-25AD-C239-AA58-8FA53DF55B79> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x4ba9000 – 0x4babff7 libRadiance.dylib ??? (???) <98EC06D5-1A02-EDEF-BF9D-2C986761AD54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x4baf000 – 0x4bd3ff7 libJPEG.dylib ??? (???) <5F2343E4-C268-B9AE-1BC3-466F5A614648> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x4bda000 – 0x4cbafe7 com.apple.vImage 4.1 (4.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x4cc8000 – 0x4cc8ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x4ccb000 – 0x4d0dff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x4d16000 – 0x4d85ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x4d8e000 – 0x51a4ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x51e6000 – 0x561bff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x57a1000 – 0x58a3fe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
    0x58f7000 – 0x58f8ff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x58fc000 – 0x59b4feb libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x5a44000 – 0x5a7eff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
    0x5a8b000 – 0x5aabfe7 libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
    0x5ab5000 – 0x5af9ff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x5b18000 – 0x5e83ff7 com.apple.QuartzCore 1.6.3 (227.37) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x5f53000 – 0x602dfff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x6078000 – 0x61b5fe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x6225000 – 0x6275ff7 com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x628d000 – 0x629fff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x62ac000 – 0x62cbff7 com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x62e2000 – 0x6313ff7 libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x631b000 – 0x633cfe7 com.apple.opencl 12.3.6 (12.3.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x6345000 – 0x6349ff7 IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x6351000 – 0x6394ff7 libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x63a2000 – 0x63adff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x63bc000 – 0x64c8fe7 libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x64e7000 – 0x64eaff7 libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x64ef000 – 0x64f3ff7 libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x64f8000 – 0x64f9ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x64fe000 – 0x64feff7 com.apple.vecLib 3.6 (vecLib 3.6) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x6501000 – 0x6583ffb SecurityFoundation ??? (???) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x65ba000 – 0x65bfff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x65c7000 – 0x65cdfe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x65d4000 – 0x65ecff7 com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x65fd000 – 0x664afeb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
    0x6666000 – 0x6688fef com.apple.DirectoryService.Framework 3.6 (621.14) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x6692000 – 0x66a2ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
    0x66a9000 – 0x67d7fe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x683b000 – 0x683bff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
    0x6c80000 – 0x6c8bff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x6c98000 – 0x6cd9ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x6efd000 – 0x6f38ffb libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistry.dylib
    0x6f53000 – 0x6f56ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x6f5d000 – 0x6f90fff libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libTrueTypeScaler.dylib
    0x6ff1000 – 0x6ff3ff7 com.apple.QuickTimeH264.component 7.6.6 (1790) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x6ff8000 – 0x6ff8ff7 com.apple.quartzframework 1.5 (1.5) <4EE8095D-5E47-1EB6-3A8A-6ECE3BEC8647> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x6ffb000 – 0x6ffbff7 com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x1b89f000 – 0x1b8acfe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) <828CCEAB-F193-90F1-F48C-54E3C88B29BC> /usr/lib/libbz2.1.0.dylib
    0x1b8b1000 – 0x1b8c4fef com.apple.FCP Uncompressed 422.component 2.0 (546.9) /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0x1b8c9000 – 0x1b8e2fe7 com.apple.applepixletvideo 1.2.29 (1.2d29) <52810348-A138-D148-92E4-9E1D73EA18A0> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0x1b918000 – 0x1c86bffb com.apple.QuickTimeComponents.component 7.6.6 (1790) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x1cb5b000 – 0x1d1d6ff7 com.apple.CoreAUC 6.11.03 (6.11.03) <42B31B0F-18F9-29D2-A67C-7B81A47F6D67> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x1d1ee000 – 0x1d4defeb +org.perian.Perian 1.2.3 (1.2.3) <722FFF4F-46EF-E5BE-70A6-42B5873D2B37> /Users/curtiswarren/Library/QuickTime/Perian.component/Contents/MacOS/Perian
    0x1d959000 – 0x1d96afff +com.media100.i.QuickTimeCodec.component 2.1 (2.1) <9195FB08-4FC2-F8F7-4E3C-42E2735BA48E> /Library/QuickTime/Media100.component/Contents/MacOS/Media100
    0x1e41d000 – 0x1e4f6fff +com.cineform.CFHDDecompressor 7.2.3.583 (583) /Library/QuickTime/CFHDDecompressor.component/Contents/MacOS/CFHDDecompressor
    0x1e5b1000 – 0x1e5ebff7 +com.cineform.QuicktimeJ2K 1.01 (1.1) <2093A555-51D9-D07C-6F1C-56C4D07AB2C5> /Library/QuickTime/QuicktimeJ2K.component/Contents/MacOS/QuicktimeJ2K
    0x1e5f6000 – 0x1e73eff3 +com.media100.HD.QuickTimeCodec.component 2.1 (2.1) <5DC39145-11DA-65AE-D4F8-DE6A4D0A4041> /Library/QuickTime/Media100 HD.component/Contents/MacOS/Media100 HD
    0x1e788000 – 0x1ee11fe7 +com.bitjazz.SheerVideoPro 2.8.0.10 (2.8.0.10) /Library/QuickTime/SheerVideo™ HD Pro Xi.qtx/Contents/MacOS/SheerVideo HD Pro
    0x1ee3a000 – 0x1ee62fe3 com.apple.AppleAVCIntraCodec 2.0 (542.4) <408052E9-3698-D679-DB45-82B57D075B22> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
    0x1ee6c000 – 0x1eeefff3 com.apple.AppleProResCodec 3.0 (544.2) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    0x1ef2d000 – 0x1efa7fef com.apple.AppleVAH264HW.component 2.0 (1.0) <6D499933-7C68-8929-0E08-ADAE036D0474> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
    0x1f06a000 – 0x1f0a6fe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1790) <6C96B4EC-ED7A-2111-5392-4C9508A8790C> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0x1f0b2000 – 0x1f0effe7 com.apple.DVCPROHDCodec 2.0 (542.4) <751976E0-619F-30A4-2EF4-60919BD28C72> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0x1f0ff000 – 0x1f1b2fe7 com.apple.AppleHDVCodec 2.0 (548.3) <7E6FD5F1-CAA5-6E72-1217-CF9F199F7EFE> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0x1f1ce000 – 0x1f1f0ff7 com.apple.AppleIntermediateCodec 2.0 (542.4) <5ED449EF-C8EE-8F39-8456-954D964A0BF7> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0x1f1ff000 – 0x1f215ffb com.apple.IMXCodec 2.0 (547.2) <10CDBF62-3937-927C-6470-E355A0232686> /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0x1f406000 – 0x1f83bfe7 com.Media100.Embedded.framework 1.0 (1.0) /System/Library/Frameworks/Media_100_Embedded.framework/Media_100_Embedded
    0x1f97b000 – 0x1fabefef com.apple.QTKit 7.7 (1790) <95F7C69A-1D24-A96A-E95D-1DF8CCD03FB3> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x1fb75000 – 0x1fba5fff com.Media_100. Media_100_Firewire 1.0 (42) <7AA446CD-289F-DB01-9823-E7BD0AEC1F2E> /System/Library/Frameworks/Media_100_Firewire.framework/Versions/A/Media_100_Firewire
    0x1fbd6000 – 0x1fc13ff7 com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x1fc2e000 – 0x1fd5bffb com.apple.MediaToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x1fdbf000 – 0x1fe06ffb com.apple.CoreMediaIOServices 140.0 (1496) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
    0x1fe27000 – 0x1fea2fff com.apple.AppleVAFramework 4.10.27 (4.10.27) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x1feac000 – 0x1feacff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
    0x1feb0000 – 0x1ff29ff7 com.apple.PDFKit 2.5.1 (2.5.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x1ff5f000 – 0x1ff86ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x1ffa4000 – 0x1ffd4ff7 com.apple.MeshKit 1.1 (49.2) <5A74D1A4-4B97-FE39-4F4D-E0B80F0ADD87> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
    0x1fff3000 – 0x1fff4ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
    0x1fff9000 – 0x1fffbff7 libclparser.dylib ??? (???) /System/Library/Frameworks/OpenCL.framework/Libraries/libclparser.dylib
    0x20000000 – 0x20098fe7 edu.mit.Kerberos 6.5.11 (6.5.11) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x200b7000 – 0x2099aff7 com.apple.AppKit 6.6.8 (1038.36) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x20e36000 – 0x212f1ff7 com.apple.VideoToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x2139a000 – 0x215c5ff3 com.apple.QuartzComposer 4.2 ({156.30}) <2C88F8C3-7181-6B1D-B278-E0EE3F33A2AF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x216a6000 – 0x21888fff com.apple.imageKit 2.0.3 (1.0) <6E557757-26F7-7941-8AE7-046EC1871F50> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x2195a000 – 0x219c8ff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x21a04000 – 0x21c4efef com.apple.JavaScriptCore 6534.52 (6534.52.7) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x21cb3000 – 0x21d09ff7 com.apple.MeshKitRuntime 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
    0x21d39000 – 0x21e3bfef com.apple.MeshKitIO 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
    0x21ea2000 – 0x21efafe7 com.apple.datadetectorscore 2.0 (80.7) /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x21f23000 – 0x21f7dfe7 com.apple.CorePDF 1.4 (1.4) <78A1DDE1-1609-223C-A532-D282DC5E0CD0> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x21fac000 – 0x21feaff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x2200d000 – 0x22015ff7 com.apple.DisplayServicesFW 2.3.3 (289) <828084B0-9197-14DD-F66A-D634250A212E> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x2201f000 – 0x2202fff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x2203a000 – 0x2207fff7 com.apple.ImageCaptureCore 1.1 (1.1) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x24c95000 – 0x2509afe7 libclh.dylib 3.1.1 C (3.1.1) <15AD52DD-FC3F-305E-5C31-699329E8FDE1> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x25166000 – 0x2518afe7 GLRendererFloat ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x25192000 – 0x25196ff7 libcldcpuengine.dylib 1.5.6 (compatibility 1.0.0) /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
    0x251bf000 – 0x251c3ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0x251c8000 – 0x251ceff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x251d3000 – 0x251fcff7 +com.grame.JackRouter JackRouter (0.9.1) <0792E479-F07C-B2DC-E7C1-216EDF6FD26B> /Library/Audio/Plug-Ins/HAL/JackRouter.plugin/Contents/MacOS/JackRouter
    0x25212000 – 0x2523dff7 +Jackmp ??? (???) /Library/Frameworks/Jackmp.framework/Versions/A/Jackmp
    0x64b00000 – 0x64b07ff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x8f0c6000 – 0x8f811fff com.apple.GeForceGLDriver 1.6.36 (6.3.6) <3BB341B6-11A7-38AD-10A3-F89506FD40D4> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x8fe00000 – 0x8fe4163b dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
    0xfa100000 – 0xfa192fe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0xffff0000 – 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
    Model: MacBookPro5,1, BootROM MBP51.007E.B00, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.33f8
    Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 256 MB
    Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
    Memory Module: global_name
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.42.4)
    Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
    Network Service: Ethernet, Ethernet, en0
    Serial ATA Device: Hitachi HTS543225L9SA02, 232.89 GB
    Serial ATA Device: HL-DT-ST DVDRW GS21N
    USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000 / 2
    USB Device: Ext HDD 1021, 0x1058 (Western Digital Technologies, Inc.), 0x1021, 0x26200000 / 2
    USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0236, 0x04600000 / 3
    USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000 / 2
    USB Device: BCM2045B2, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000 / 2
    USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000 / 5
    Floh Peters replied 12 years, 12 months ago 2 Members · 2 Replies
  • Marcus Warren
    September 7, 2013 at 11:53 pm
    A reinstall has apparently fixed the problem.
  • Floh Peters
    September 8, 2013 at 2:35 pm
    Glad you solved it
