Activity Forums DaVinci Resolve Can’t get LUT to work
  • Can’t get LUT to work
    Posted by Toby Tomkins on July 25, 2011 at 3:47 pm
    Hey,
    I’m struggling to get a .cube LUT to work in DaVinci. I’ve tried it in both the Kodak and Cinespace folders in the LUT folder of the Resolve application support folder.
    (LUT at end of post)
    Any ideas?
    EDIT: to be more specific, when the LUT is loaded Resolve displays black.
    Resolve 8.01
    LUT: 2672_loglinprintrec709b.cube.zip
    Sascha Engel replied 11 years, 2 months ago 4 Members · 4 Replies
  • Rohit Gupta
    July 26, 2011 at 3:17 am
    Hi Toby,
    We tried this on a few machines here. It seems to work for us, both OpenCL and CUDA.
    /Library/Application Support/Blackmagic Design/DaVinci Resolve/LUT/CineSpace
    Could you make sure the account you are running this from has write permissions in the folder? There should be a file with the same name and with a 3dlut extension and with a size of 431244 bytes.
    Regards,
    Rohit
  • Toby Tomkins
    July 26, 2011 at 9:16 am
    That’s odd, that file wasn’t there before, but it is now, after several ‘refresh list’ clicks in the LUT tab and several restarts of DV.
    p.s. Anyone want to share a RedLogFilm to RedGamma/RedColor2 LUT?
  • Mike Most
    July 26, 2011 at 4:28 pm
    https://www.arridigital.com.
    Go to the LUT generator and make a LogC to Video LUT, extended range in and out, no matrix. Force 3D LUT generation, select DaVinci format.
  • Sascha Engel
    July 9, 2015 at 5:25 pm
    THANKk YOU SOOOOOOOO MUCH!
    I had a problem similar for ages now.
    Your hint with the permissions fixed it and I was trying EVERYTHING before.
    Big HUG!!!!!!
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
