Can’t Get Levels to match from FCP to RED to FCP
I’ve captured some video, turned them into freeze frames and exported them from FCP 5.1.2. Then I added this still (.pct seemed to make the right size, as .tif cut off some black at the edge) to my RED 4.1 composition (4:3 aspect ratio, Z=0). Exported a movie 1 frame long as FCP 10bit uncompressed, also as None (Best), and when I import those movies back into FCP the levels are off. The black levels drop down and the vector shifts a few degrees (slightly noticeable in facial flesh tones). How do I get the levels to match between the applications?
