Activity Forums Apple Final Cut Pro Legacy Can’t get FCP 6.0.6 onto new MacBook Air
  • Can’t get FCP 6.0.6 onto new MacBook Air
    Posted by Kenny Holl on April 9, 2015 at 9:08 pm
    I currently have an iMac, running Mavericks (10.9.5) that uses Final Cut Pro 6 (version 6.0.6) and I love it. But when I go out of town, it would be helpful if I could also work on my projects then. So I bought a new MacBook Air. It uses Yosemite (10.10.3). When I tried to install FCP 6 from the discs that I have, I did have a little difficulty getting it loaded, but it did appear to eventually load because I was able to open FCP. But after plugging in my external drive with the projects I have been working on, I tried to open one of those projects. It would not open, giving me the warning “File’s format is too new for this application.” It trend out that when I loaded the application, it only loaded version 6.0.1. I called Apple to see if there is a way to get 6.0.6 instead of 6.0.1 and they said there is no way to get that update. So, what can I do? Is there any way for me to run FCP 6.0.6 on this computer? It runs great on my iMac, and I do not want to upgrade to FCP X. Would it work if I got an older used MacBook? Still, how would I upgrade from the 6.0.1 that the discs give me to the 6.0.6 I need to work?
    Alex Kaloostian replied 11 years, 5 months ago 3 Members · 2 Replies
  • Shane Ross
    April 9, 2015 at 11:33 pm
    You’ll need to find someone who has that update archived. Someone who downloaded it instead of doing a SOFTWARE UPDATE…and who kept it. That’s the only way you’ll be able to update to 6.0.6.
    And don’t expect FCP 6 to be fully compatible with 10.10. That’s about four OS versions past the one that did support FCP 6. Two past the ones that supported FCP 7.
    Shane
    Little Frog Post
  • Alex Kaloostian
    April 10, 2015 at 12:06 am
    https://support.apple.com/kb/DL854?viewlocale=en_US&locale=en_US
    “I’m Alex Kaloostian, and I approve this message.”
