Activity › Forums › Avid Media Composer › Can’t get audio OMF export under 2 GB
  • Can’t get audio OMF export under 2 GB
    Posted by Phillip Roh on April 2, 2007 at 1:52 am
    Hello, I have a ~35 minute short film and trying to export an audio OMF for audio finishing. I have 8 tracks of audio, 48 KHz, 16-bit. Problem is that I keep getting an error (SYS_ERROR) because the OMF file hits the 2 GB ceiling (I checked the file size as it was being created).
    I tried deleting all video and all other audio tracks (leaving one), setting a tiny in/out, but I still get the same error. Any ideas why this is happening?
    John Steventon replied 19 years, 6 months ago 3 Members · 2 Replies
  • John Pale
    April 2, 2007 at 5:24 am
    Is the audio in your sequence all from group clips?
    It always includes audio from all angles in an embeded OMF. this is a known problem.
    Try consolidating your sequence to another drive or workspace and then export again.
  • John Steventon
    April 3, 2007 at 7:25 am
    Just a quick thought on this, in case you bypassed it in a rush.
    Though you’re setting a small in and out – you HAVE set the export settings to ‘Use Marks’ haven’t you? If you’ve not, it’ll export more than you expect.
    Like I said, it’s unlikely you’ve not checked this, but best to cover all bases.
    However, even if it was 8 tracks, filled with audio for 35 minutes, you wouldn’t hit the 2Gb limit (it my addition is right).
    I hope this is too late, and you’ve already sorted the problem.
    (Oh, second option – how about consolidating the audio to another drive, and exporting only a linked OMF file (rather than an embedded one)?
    John Steventon – Author of DJing for Dummies and freelance Avid and Final Cut Pro editor. Remember – Music is the Answer.
    Success is merely a failiure to imagine more…
