Activity Forums Blackmagic Design Can’t get audio from spdif/aes in
  • Can’t get audio from spdif/aes in
    Posted by Jack Bone on November 7, 2006 at 9:14 pm
    I’m trying to capture digital audio with the decklink HD pro, SPDIF/AES input. The audio comes from a Sony DAT machine that I can control with the remote cable, but I can’t get any audio signal, The DAT works fine I had tested it, I had checked the preferences: decklink preferences are set AES/EBU input, and G5 audio in preferences are in decklink. I don’t get any audio signal in FCP capture neither in the G5 audio in preferences.
    Please help.
    Thanks.
    Tycho Sjögren replied 19 years, 1 month ago 5 Members · 10 Replies
  • 10 Replies
  • Vidoje
    November 8, 2006 at 5:42 pm
    SPDIF is for monitoring (output) only! So no way you can capture on DeckLink via this jack.
  • Jack Bone
    November 8, 2006 at 7:32 pm
    Hi.
    Thanks Vidoje, but I still don
  • Jack Bone
    November 10, 2006 at 5:37 pm
    Hi.
    I red that the Decklink can’t capture audio unless you capture video at the same time, is this true?
    Is really no way to capture just audio?
    Jack.
  • James Reid
    November 12, 2006 at 6:06 am
    If the DAT machine has has an SP/DIF optical out,
    why not just plug it into your G5’s optical input?
    Use any audio app to capture it.
  • Jason Levy
    November 13, 2006 at 6:24 pm
    It likes to see a signal on the video in but you aren’t obliged to capture it.
    jason
  • Jack Bone
    November 15, 2006 at 11:16 pm
    Ok thanks Jason, I would try to capture only audio with a video signal too. but I don
  • James Reid
    November 16, 2006 at 12:00 am
    [Jack Bone] “I need to capture in 48000 Hz, G5 audio in is just 44100 Hz”
    Not true.
    Open “Audio MIDI Setup” (in Utilities folder) and choose you sample and bit rate there.
  • Jack Bone
    November 17, 2006 at 12:30 am
    Hi, Built in audio hardware at any apple computer have allways been limited, I don’t know why but many times is a problem. It can’t in any way capture audio in a different frequency that 44100 Hz. Try Audio MIDI Setup as you say and will see.
    Thanks a lot anyway.
    But still need a solution with the decklink, At least would like a technical explanation why I can’t capture audio whithout video. Any Blackmagic engineer come here and fix the board! 🙂 (Hey, until now DeckLink worked just great, best quality and best price for hard work HD 444 capture)
    greetings.
    Jack.
  • Jack Bone
    December 2, 2006 at 2:45 am
    Sorry, I was wrong, G5 built in audio It does can capture in 48kHz.
  • Tycho Sjögren
    August 27, 2007 at 4:43 pm
    Did you ever get an answer for this question?
    A costomer of mine is having the same problem
